Originally Posted by djnitr8
hey ppl... jus wondering, does any 1 have an idea on how 2 convert a right hand drive 2 left hand drive and how much would it cost n where can i get the parts 2 do it..... also does any 1 knw if it is possible 2 change the nsx automatic gear box to a manual gear box...thnx.
Register at nsxprime.com and do a searh for right hand drive conversion, there is a member there who did this and documented the entire process. Its not for the weak minded, it involves hacking up the front firewall and welding in a new one to move the break booster and clutch cylinders. As far as swapping from automatic to manual, its as simple as getting the manual transmission you can purchase the 6 speed tranny + lockout kit
here then all you have to do is source an ECU for a manual tranny car and your golden (the automatic ecu's have the vtec level set different and shift much lower)
