Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > S2000 Forum
Old 02-21-2008, 01:31 PM   #1 (permalink)
Smurf350z's Avatar
Car: 2005 S2000
Mods: Invidia T1 Exhaust, CAI
Smurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peonsSmurf350z Hello down there miniscule peons
ITB Setup
I am trying to do a little research on an itb setup for my ap2....does anyone else have some kind of itb setup....I was looking at something from here....any suggestions TWM-Throttle Bodies-2000 Series
My Drift Car KA-T Build
Smurf350z is offline
Old 02-21-2008, 02:11 PM   #2 (permalink)
Car: 01 S2000, 95 Accord (daily driver)
Mods: None
adnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a lifeadnohc02f You need a life
I remember reading in a Honda Tuning issue about a guy that did a ITB setup on his ap2. the ITB was the only thing he did, and he was runing AEM EMS for tuning. I think the HP gain was about 25hp.
adnohc02f is offline
Old 02-21-2008, 02:29 PM   #3 (permalink)
Clone's Avatar
Car: 2001 Honda S2000
Clone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sadClone is sad...just sad
ITB's are a huge pain in the ass, and I would highly recommend NOT installing them on a street-driven, and definitely not daily driven, vehicle. Not to say it cant be done, only that it will cause many drivability problems, mostly at idle.
I looked into doing a setup for my S2K a while back... I got some used throttle bodies from a Hayabusa motorcycle... then had a stock S2K intake manifold cut and welded to the throttles. Mechanically, I could have gotten it to work. But as far as tuning and drivability goes, it's a total nightmare even when running a standalone management system. I still have the parts, I can post some pics if you like.
But... if you're still interested in learning as much as you can... check the FAQ for two incredibly helpful links, or you can click this one below:
My DIY Individual Throttle Bodies Project
This thread is probably the best info you'll find on modding ITBs to fit on a honda motor. Keep in mind, that it's all just theory and I dont think Blake ever got it working right, and the project was abandoned. But you can find a TON of good info in there, so it's a good starting point. That thread focuses on building an H22 Prelude, not an S2K... but the principles are the same and can be applied to basically any FI motor.
2001 Honda S2000
201.63 whp : 135.74 ft/lbs
Myspace
Clone is offline
Old 02-22-2008, 08:39 AM   #4 (permalink)
Smurf350z's Avatar
Car: 2005 S2000
thanks for the insight....I am gonna do some more reading but I think if its gonna be that big of an issue especially with tuning I might figure something else out
Old 03-30-2008, 12:29 AM   #5 (permalink)
Mountain-man's Avatar
Car: 2003 S2000 , 2003 Mazda Protege5 DD
Mods: Tanabe Concept G dual exhaust, Tracy Sports TS-02 manifold, Spoon CK plug cover, misc carbon bits, Spoon 4POTs ORDERED!, (Coming soon>> Spoon rotors, wheels-18" Volk GT-C, coilovers- still reserching,
Mountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphereMountain-man In the rep troposphere
Bulletproof Automotive Tracy Sports setup
Bulletproof Automotive Toda setup
ITBs are beasts. They look like gold, sound like gold, produce like gold, and costs almost as much as gold. I looked into the Tracy Sports set a while ago along with a couple others for mine. Yeah, they kinda wreck the drivability of the car. I think Clone touched on that when I was asking the same questions back then. I'm pretty sure you will need an EMS tune for your engine to work right.
Not only that, but there will no longer be any filtration element to keep dirt and debris out of the engine. If you drive the car on a regular basis, I would immagine your cylinder walls will become scored and gauled quickly depending on driving conditions. If I recall, someone here pointed out that you can get little filter-booties to go over the horns, but at that point, why bother? . . . I supose you could take them off for show purposes, and keep them on for driving.
Hot stuff.
I like to get high in the summer!
Mountain-man is offline
Old 03-30-2008, 04:33 PM   #6 (permalink)
jarrod_aspden's Avatar
Car: 2001 s2000 - 1995 Prelude si
Mods: s2000 FIPK K&N air intake, NGK iridiums, custom oil catch tank, custom radiator cooling plate and tsw tracklites. - 1995 Prlude si fuckin thieves!!!
jarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these partsjarrod_aspden is infamous around these parts
If you interesed in itb then go to inline4.com they have todas for 2,800 bucks.
I gotta AP1!!!
I'm a welder
jarrod_aspden is offline
Old 03-31-2008, 09:29 AM   #7 (permalink)
Smurf350z's Avatar
Car: 2005 S2000
yeah I found a set for 1300 dollars but I am leaning against it now....just due to the massive amounts of tuning they involve just to get them to idle correctly.....and really for not that much of a hp gain....yeah they look cool....but weighing my options I would be better off rebuilding the shortblock to a lower compression and boosting
Old 03-31-2008, 07:21 PM   #8 (permalink)
Hey man before you make your decision check this vid out. Maybe you can contact this guy to see what tuning methods he used etc. His shit sounds fucking amazing.
YouTube - Pacman S2000
I gotta AP1!!!
I'm a welder
Old 04-01-2008, 11:06 AM   #9 (permalink)
Smurf350z's Avatar
Car: 2005 S2000
yeah team pacman....that shit is awesome....they spent quite a long time tuning that thing though....I dunno if I am prepared to do that to my daily driver or not
» Site Navigation
» Home
 > FAQ
» Other Sites
