wondering if anyone has some input on this. I have an 07 s2k and want more. any suggestions on this type of spray with out going super or turbo charged??
__________________ WE ALL PLAY ..........BUT SOME PLAY TO WIN!!!!
I work at a honda dealership and found out that all this injection will do is lower temps to be able to boost higher to prevent detination thanks for the responce but i think were just going to give it a nos bottle at around 125 boost is that ok for a stock motor or should i keep it lower???
boost??? You mean a 125 shot? I would not go that high on a stock motor.
I would stay with a 75 shot with some colder plugs. BTW please dont call it NOS, it sounds like your on F&F lol. Its nitrous (NOS is a company) and n2o is the short name for nitrous. And run you def want to run a wet kit
THE WET SYSTEM IS A DEFINITE AND I DID NOT REALIZE THAT I HAD TO USE DIFFERENT PLUGS. PS AND YOUR RIGHT I SAY THAT OUT OF HABIT FOR NITROUS OXIDE. WHAT DO YOU THINK AN AVERAGE PRICE IS FOR A COMPLETE SYSTEM AND I WANT TO INSTALL THE RPM SETTING THAT LETS YOU SET A "WINDOW OF OPPORTUNITY" EXAMPLE 3500 TO 8000 SORRY ITS AP2 LOL.
man you should read up on nitrous before jumping in.. well that's anything, but yeah i would spend some time researching how nitrous is used properly if i were you. there is lots of info in the n2o forum here. good luck with your project.
i guess im justing reaching for power because of my drive by wire situation. i have talked to several people in the past couple of days and a wet 100 to 125 should be ok as long as i dont stand on it all the time.
Mods: Custom Airbox, sway bars, Full Helix TBE and catless uppipe, Open Source tuned by yours truly, and many other goodies
+1 for researching nitrous more before running it. The following is not a cut down just opinion in the hopes you dont blow your motor. Knowledge that once you get to a point in nitrous that you have to run colder plugs is nitrous basics. Just do some homework and your experience and motor will be much happier.
subaru right now but looking to join the honda family again....
