Originally Posted by chrisjm00
And also, you use the old piston and springs with the new tensioner right?
No, the part comes with entirely new piston, springs, everything you need. The reason you're replacing it is because the springs inside have worn over time, and no longer hold the piston with the proper amount of pressure to keep tension on the timing chain.
THe old piston and spring components will slide out of the tensioner housing with some ease... so be careful when you're pulling it out, because they're not held in place with anything...
just another note... dont remove the pin off of the new tensioner until after you've installed it. The pin must be removed through the maintenance hole after the install. If you remove the pin beforehand, you've just wasted a brand new tensioner, cause there isnt any way to get it back in again, and you cant install it otherwise.
