i was supposed to run the sentra on friday but when the time to run came closer the excuses started to come.
but i did get to run the 5.0 and i got it on video. the mustang was stock and the em1 had a 8lbs flywheel, stage 2 clutch and cai. the only downside was that i didnt get to race, by brother said its not safe for me because the brakes on the car are not that good ( im only 16).
my brother raced on his terms (from a launch and ended up winning by a fender. the main reason we won by a fender was because my brother was not shifting fast. if i raced the em1 would have won by alot more.
after the race i found out my brother put 89 octane in the em1. i felt bad for the car because i heard it knocks if its anything under 93.
if it was 93 im sure i will beat him by alot more.
Need more info, what kind of Sentra,and Motor , What motor do you have (b16)
__________________ Myspace.com
Porn should only be a brief guide into what the
standard should be when you look for a girl, to trigger a reaction of self-improvement and become a Master Pimp, so others can either follow the example or look with envy when you have a porn-quality woman in your arm, regardless of economic status quo.
the 01 sentras come with sr20s(non turbo). i have a b16a2.
When you say Fresh Motor, Was It Rebuild for Performance ???
if not
we'll I say If you don't pass him By third Gear then you losts
Hmmmmmm. a Fresh B16a2 8lbs Flywheel, Cold air intake, you have a Strong Chance of Beating him, The only Advantage he Has is Header Post A video up
