211-MPH Civic Specs:
Dart Block 84mm bore
Eagle 87.2mm Crank
Probe Rods (GSR)
Probe Forged Pistons (84mm flat top)
Dart B18C Head
Cometic Head Gasket
Skunk II Stage 2 Cams & Sprockets
Skunk II Intake & Holley TB
720 cc RC Injectors
HP Performance Turbo Manifold
Turbonetics T72 Turbo
Spearco Air-to-Water Intercooler (Dual Core)
Vortech BOV
Tial 44mm Waste Gate
MSD Distributor & Ignition
Hondata S300 Management
4-Inch Oval Borla Exhaust
Hasport Engine Mount Kit
Snow Boost Cooler (Water/Methanol)-Water only in gas class!
Street-17x7 5Zigen Wheels
Street-BFG 205/55-17 Tires
Bonneville-15-inch Steel Wheels & Moon Disc Covers
Bonneville-15 x 4 x 26 Goodyear Eagle Front Runner Tires
B18A Trans with Custom Ring & Pinion
ACT Clutch, PP & Flywheel
Custom K&N Filter & Air Intake System (into turbo)
Fluidyne Radiator
Denso IQ31 Spark Plugs
Innovate Air/fuel meter
728 hp, 503 lbs. ft. at 29 psi (Flywheel hp)-Measured On Superflow Engine Dyno
517 hp 351 lbs ft. at 17 psi (Wheel hp)-Measured on DynoJet Chassis Dyno
Vehicle:
1999 Honda Civic Si (only 12K original miles)
Eibach Coil Over Suspension
5Zigen Wheels (street)
BFG Tires (Street)
Goodyear Front Runner Tires (26 x 4.5-inch) for Bonneville Runs
Factory Steel Space Saver Steel Wheels (seam welded & Moon Hub Caps-Bonneville)
Custom rear wing, front spoiler, belly pan, parachute mount, aluminum work, roll cage, fire system, cover plates, seat mounting, dash mods-Fabricated by Bernie van Hamond & Tom Habryzk
13-inch Ft. Baer Brakes-Street
Stock Ft Brakes-Bonneville (Hawk Pads)
SPC Adj Suspension Components
