Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda Lifestyle & Entertainment > Off-Topic Lounge > Sports & Recreation
Old 05-23-2007, 12:10 AM   #1 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
spyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep troposphere
lifting and cardio question
I started to lift 3 times a week now for 2 weeks and decided that i need to start doing some cardio to get the fat off of my abs. I'm by no means fat, I'm 5' 10" and only 160 last I checked, it's just all on my abs. I used to have a 7.7% body fat when I was in High School playing Basketball, it has to be at least 12 now. I've already started to eat better and more(4-5 times a day)which jumped my energy up alot. Should i jog, sprint or what? for how long? and when should i do it?
92 Prelude Si
Engine/Power - H22A, short ram with BPi stack/K&N, Professional Products 68mm throttle body, Euro R intake manifold, Hondata gasket, OBX header, Tanabe Racing Medalion exhaust, NGK Iridium plugs, Vision plug wires/cap, MSD coil, Carbing catch can
Tranny - M2B4, Centerforce stage 3 clutch, unknown light weight flywheel, shortshifter
Suspension - KYB AGX struts, Tanabe springs, Megan Racing front/rear strut bars and rear tie bar
Brakes - unknown slotted/cross-drilled rotors, Axxis pads, red calipers
Now to put on the RS*R header and a 3" exhaust.
spyder06 is offline
Old 05-23-2007, 12:14 AM   #2 (permalink)
jon
jon's Avatar
i perfer to do the eliptical machines for at least 45 min
silence is golden
but duct tape is silver
jon is online now
Old 05-23-2007, 12:18 AM   #3 (permalink)
Dark Samurai
Tony_Bolony's Avatar
Car: 2006 WRX
Mods: Espelir CB, Swift Lowering Springs, Titek DP, HID's
Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?Tony_Bolony you're still here?
If you have good knees, you can do running and jogging. I think it is better to actually run outside, than on a treadmill because it is also more difficult to do so, and you get more out of it.
If your knees are like mine and not very good, you can do the stair master, elliptical machine like jon said, or the stationary bike. All are good and do the same thing basically.
Make sure to mix up the speeds too, go faster for a bit and then slow it down and then pick it up again.
Old name was Altronx
Tony_Bolony is offline
Old 05-23-2007, 12:19 AM   #4 (permalink)
jon
jon's Avatar
and do it with incline so you shred your core too
silence is golden
jon is online now
Old 05-23-2007, 12:22 AM   #5 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
I'm just lifting at home so the machines are out of the picture.
Also should I jog on the days I'm lifting or should I do it on the off days?
92 Prelude Si
spyder06 is offline
Old 05-23-2007, 12:23 AM   #6 (permalink)
jon
jon's Avatar
i have cardio days seperate from lifting days
silence is golden
jon is online now
Old 05-23-2007, 02:36 PM   #7 (permalink)
Dark Samurai
Car: 2006 WRX
Its good to do what jon said and do cardio on separate days than your lifting days. But it is also good after you do your workout, to go jogging or something for about 10 to 20 minutes. It will work you twice as hard because you just spent the last however long you spent working out, and now you go and run, it will definitely work you harder, but be more fulfilling.
Old 05-23-2007, 02:47 PM   #8 (permalink)
Cypher Wave
Transparent's Avatar
Car: I dont own a car
Mods: fuck off
i do cardio every day i can. if i lift i do cardio for a shorter period of time though
Transparent is offline
Old 05-23-2007, 05:07 PM   #9 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
I think I'll just jog after I lift. Then spend the other days resting.
92 Prelude Si
spyder06 is offline
Old 06-01-2007, 01:01 PM   #10 (permalink)
Car: '98 GSR
DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!DRVIC Um, 1 million? Damn!
If I am lifting on that day I only do 20 mins of cardio. On off days when I am not lifting I do about an hour or so. I use machines cause I have bad knees but I always try to mix it up...
DRVIC is offline
Old 06-02-2007, 11:54 AM   #11 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
I checked my weight and shit and I'm 156 pounds and 13.5% body fat but, that was after eating a huge dinner. I was really surprised that I was only 156. I haven't started jogging yet because I've been really busy lately. I do feel like I've lost some weight just by eating better.
92 Prelude Si
spyder06 is offline
Old 06-02-2007, 11:55 AM   #12 (permalink)
Cypher Wave
Mods: fuck off
going from a shitty diet to a good one is the fastest way to get initial results
Old 06-02-2007, 12:06 PM   #13 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
Yeah I was eating 2 times a day, now I'm eating like 4 times a day and I'm eating stuff that's better for me. I'm not sure if I've lost weight though sence I didn't weigh my self before. My energy threw out the day is 100% better.
92 Prelude Si
spyder06 is offline
