Go Back   Honda Forum / Acura Forum - SuperHonda.com > Acura - Vehicles > TSX Forum
Old 02-13-2008, 09:32 PM   #1 (permalink)
AcidLotus's Avatar
AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus
2009 TSX
All-New 2009 TSX to Debut at New York International Auto Show
The second-generation Acura TSX is designed to appeal to young professionals with its keen-edge styling, athletic performance and advanced electronic features
TORRANCE, Calif., U.S.A., February 11, 2008– Designed and engineered to reaffirm its place as a desirable and affordable entry point for entry-premium buyers, the all-new second-generation 2009 TSX is larger, more agile, more performance minded and even “more Acura” than ever before. Carefully crafted to honor the original TSX’s vision as a world-class sports sedan, the new TSX has significantly evolved to offer more comfort, convenience, driving performance and safety. It does so with expanded luxury and electronic features, a wider stance for more agile performance, and advanced safety systems.
The 2009 TSX is expected to appeal to current TSX owners, young professionals and other image seekers who will appreciate its innovative styling, technical allure and total performance – while also valuing the outstanding customer treatment that owners have come to enjoy at Acura dealerships. Extremely brand conscious and eclectic in their tastes, buyers will find the TSX as satisfying for driving colleagues to lunch as it is for weekend snowboarding trips or vacation travel.
Powertrain
An all-aluminum DOHC i-VTEC® in-line 4-cylinder engine heralds a pair of firsts for the TSX model, including dual balance shafts and a direct ignition system. Along with improved performance, it is also cleaner as it now meeting the EPA’s aggressive Tier 2-Bin 5 and CARB LEV II Ultra Low Emission Vehicle (ULEV) standards for the first time in TSX history.
Displacing 2.4-liters and producing 201 hp and 172 lb-ft of torque (with manual transmission), the new in-line 4-cylinder engine produces its useable power across a much wider rpm range, while five percent more torque further strengthens the engine’s pulling power at middle rpm levels. This allows the 2009 TSX to be more responsive off the line and out of corners, and stronger in the middle of the rpm range where the engine operates most of the time.
This newfound performance and flexibility is due in part to a higher compression ratio, revised valve timing, and improved intake and exhaust gas flow. Further credit goes to the TSX engine’s i-VTEC® "intelligent" valve control system, which provides the power characteristics of a V-6 without sacrificing the light weight or fuel efficiency of an in-line four. Likewise, a new rear-mounted exhaust manifold layout, a close-coupled catalytic converter design, and a Programmed Fuel Injection (PGM-FI) system substantially reduce emissions levels. Estimated fuel mileage is 21/30/24 mpg* (city/highway/combined, 5 AT) and 20/28/23 mpg* (city/highway/combined, 6 MT).
Two transmissions are available, both as standard equipment – a 6-speed close- ratio manual with new performance-oriented ratios for Second through Sixth gears, and a Sequential SportShift 5-speed automatic with a new lock-up torque converter assembly. The manual transmission features a short-throw shifter with a precise, light action that makes it highly rewarding to use, while the Sequential SportShift automatic permits fully automatic operation with intelligent features such as Grade Logic Control and Shift Hold Control, which make driving the TSX on hilly or winding roads more enjoyable. If the driver desires, the automatic transmission can also be operated manually via new steering-wheel mounted F1®-style paddle shifters.
Body and Chassis
The 2009 TSX body structure includes two firsts for the Acura division, including a closed-channel cross-braced roof structure and inside frame rails. Along with a stronger rear bulkhead, the closed-channel cross-braced roof structure yields a more rigid and vibration-resistant structure. The first use of inside frame rails for any Acura model help tailor the aerodynamics underneath the car for improved fuel economy, lower emissions and reduced noise. In addition, new A-, B- and C-pillar separators improve the TSX’s quietness over rough roads and at high speed. Slippery aerodynamics also helps fuel economy as well as high-speed stability – all while lowering emissions.
In addition to its 3.0-inch greater width and 2.6-inch wider track, the 2009 TSX has a 1.3-inch longer wheelbase and 2.4 inches more overall length. These dimensions combine to provide greater interior roominess, more agile handling and improved ride quality. Another first for Acura are the TSX’s new dual-mode suspension dampers, which provide superior suspension damping characteristics at both lower and higher damper speeds. Using a unique deflector plate stack, the new dampers adjust compression damping characteristics to suit the vehicle speed, cornering forces and road surface. In creating the second-generation TSX body design, Acura designers sought to retain the crisp, dynamic design of the original and enhance it by widening the body overall and adding more muscular and distinctive cues to create a keen-edged sports sedan. Their key design goal was to create an aerodynamic design that evokes both emotion and tension with a decisively sporty flair.
Outward visibility is improved with a slimmer A-pillar design, while an auto up/down front passenger window adds convenience and a reverse-linked passenger-side door mirror tilts down to help improve safety while parallel parking. The new TSX also has a wider trunk opening and a lower trunk lift-over height for more convenient loading.
Exterior/Interior
Functionality and refinement converge with luxury and style in the interior of the 2009 Acura TSX. Featuring a blend of sweeping, contemporary shapes, a high level of standard comfort and convenience features, widespread use of premium materials and an available Technology Package, this 5-passenger sports sedan offers the upscale modern interior that customers have come to expect from Acura.
From the precision-crafted metal door sills to the satin-metal finish accents, from new leather-covered seats to the steering-wheel mounted controls, and from the premium 7-speaker sound system to the dual-zone automatic climate control, the TSX represents a merge of intelligent design and innovation. For example, Bluetooth® connectivity is standard and includes a HandsFreeLink® cellular telephone interface that makes communications easier and safer while en route.
Typical of Acura, the TSX offers an exceptional level of standard equipment. Included are a standard power passenger seat, a new folding key with remote entry, new automatic headlight activation, a premium 7-speaker sound system with CD, AM/FM/XM®, Bluetooth® HandsFreeLink® , and USB port music interface. A HomeLink® remote control system is also standard.
Adding to the already impressive list of TSX standard equipment is the available Technology Package, which bristles with leading-edge electronics that make driving much more efficient and enjoyable. These include an Acura Navigation System with Voice RecognitionTM, AcuraLink® Real-time traffic, AcuraLink® weather, and the highly useful AcuraLink® Satellite Communication System. The navigation system also features Real-time trafficTM covering 76 major metropolitan markets, and offers Traffic Rerouting with dynamic route guidance to help navigate around slow-downs. For 2009, the TSX receives a dash-mounted electronic compass for added directional information while driving.
Included in the Technology Package is a premium sound system tuned by legendary sound engineer Elliot Scheiner. This 10-speaker Acura/ELSTM Premium Surround Sound System with DVD-Audio includes a new Note function for XM® Radio that makes it easy to identify songs to recall at a later date. With push of a button, the Note function can capture 10 seconds of up to 30 songs, along with noting text indicating song title, artist name, and XM® channel.
Safety
The 2009 Acura TSX leads the way in safety with its new Advanced Compatibility EngineeringTM (ACETM) body structure. Engineered into the TSX model for the first time, ACETM improves the dispersal of frontal crash energy through the use of load-bearing frame structures that better match the TSX with other vehicles of different sizes and with different bumper heights. Simply put, ACETM helps maximize the effectiveness of the TSX’s front crumple zones, better dispersing crash forces before they reach the passenger compartment.
A broad range of passive safety features likewise contributes to occupant safety, including six airbags (dual-stage, dual-threshold front airbags, new dual-chamber front seat side airbags, and side curtain airbags for outboard seating positions). Three-point seatbelts and head restraints are provided in all seating positions, and front seatbelt load limiters with an integrated automatic tensioning system further protect the TSX driver and front passenger. A new Active Headrest Restrain System is used for the first time on the TSX, while the rear seat features a Lower Anchors and Tethers for CHildren (LATCH) system that allows for the easy and secure affixing of up to two child seats. Exterior features designed to further improve safety include daytime running lights (DRL), pedestrian-injury mitigation features such as a deformable hood, hood hinges and windshield-wiper pivots, and a 5-mph front bumper and 2.5-mph rear bumper. The 2009 Acura TSX is expected to achieve the highest ratings in both government (NHTSA)** and independent (IIHS) crash testing – including garnering IIHS’s TOP SAFETY PICK.
Finally, the 2009 Acura TSX is covered by a comprehensive 4-year/50,000 mile bumper-to-bumper limited warranty and a 6-year/70,000 mile powertrain limited warranty. Additional benefits of ownership include Acura Total Luxury Care® (TLC®) that provides free 24-hour roadside assistance, concierge service and trip routing.
2005 TSX 6MT + Navi
AcidLotus is offline
Old 03-19-2008, 09:42 PM   #2 (permalink)
AcidLotus's Avatar
Official Photos:
Autoblog
2005 TSX 6MT + Navi
Old 03-19-2008, 09:46 PM   #3 (permalink)
MadScientist305's Avatar
Car: 1997 Civic Ex
Mods: TD04h Turbo @ 6 psi, FMIC, Additional Injectors, fuel pump, Clutchmasters Stg. 4 , fidanza flywheel
MadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to doMadScientist305 Rep God/Goddess with nothing better to do
meh, i don't know...looks like one of those mazda 6's or w/e.
My Car Info Thread
MadScientist305 is offline
Old 07-29-2008, 02:27 AM   #4 (permalink)
Car: 07 cl9 tsx
Mods: Greddy evo2, black-out, led lighting
mclovintsx is on a distinguished road
hey I didn't know you were a moderator here acidlotus! remember me from another forum?
mclovintsx is offline
Old 07-30-2008, 08:38 PM   #5 (permalink)
AcidLotus's Avatar
Yeah, McLovin. From the Superbad movie, right?
"McLovin is a bad-ass!"
2005 TSX 6MT + Navi
Old 07-31-2008, 05:20 PM   #6 (permalink)
vindawg1's Avatar
Car: 08 si
Mods: fujita sri
vindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratuspherevindawg1 In the stratusphere
When I first saw these things I thought they were pretty ugly, but my buddy has one and I took a ride in it and it's actually pretty sweet. Haven't raced him in the si yet but I'm curious to see how I would do against it.
99 integra ls - aem intake, n1 exhaust, pioneer head unit - sold
08 nhb civic si coupe - jdm emblems, fujita intake
vindawg1 is offline
Old 07-31-2008, 06:34 PM   #7 (permalink)
HonduhDave's Avatar
Car: 2000 Honda Civic EX Sedan
Mods: Nothin much yet...17x7 Tenzo Shu-4 knock-offs w/ Falken tires, RActive exhaust, 20% Tint, Full Custom Stereo, fully dented up exterior waiting for work
HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?HonduhDave you're still here?
definitely not interested. I love the first-gen TSX, but it looks like I'll be looking for a used one when I finally make the switch. More weight w/o additional power. Doesn't look as clean and understated as the original. It's not for me...
4 Doors are the best!!
Originally Posted by WVU97GS-R View Post
Race
Inspired
Cosmetic
Enhancement
Civic "Re"build Thread
HonduhDave is offline
Old 07-31-2008, 09:18 PM   #8 (permalink)
AcidLotus's Avatar
08 SI will most likely win by about a car length, maybe a car and a half, unless he has an auto, and then the gap will widen significantly.
2005 TSX 6MT + Navi
Old 09-24-2008, 06:11 PM   #9 (permalink)
kenman923 is on a distinguished road
I was looking at the Accord and then I drove the TSX. I think I am looking more at buying the TSX.
kenman923 is offline
Old 09-24-2008, 06:36 PM   #10 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
i hate balance shafts....
http://www.team-integra.net/sections...p?ArticleID=48
for all you noobs who think back pressure is a good thing
http://www.superhonda.com/forum/f30/...please-333110/
Originally Posted by HonduhDave View Post
He's not Japanese, he was referring to the languages he can speak. He's capable of speaking English, can probably curse and ask for a beer in Spanish and has heard his girl moan in Japanese in bed
WVU97GS-R is offline
