Go Back   Honda Forum / Acura Forum - SuperHonda.com > Acura - Vehicles > TSX Forum
Old 04-13-2006, 07:43 AM   #1 (permalink)
JstAneon has a spectacular aura aboutJstAneon has a spectacular aura aboutJstAneon has a spectacular aura about
TSX Key Question
Does an ignition key for a TSX have a chip imbedded in it? I ask because my wife took it to the stealership yesterday to get a new key made. They told her it would be something like $150 to program the the chip inside the key. Do I need to go over there and make a scene?
It's just a neon. :byye
JstAneon is offline
Old 04-13-2006, 11:21 AM   #2 (permalink)
Dark Samurai
Squirrel's Avatar
Car: 1986 Mazda Rx7, 2004 Nissan Xterra SE
Mods: 5-lug swap
Squirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapySquirrel needs rep therapy
yep... the keys cost that much... and are chipped
Squirrel is offline
Old 04-13-2006, 11:23 AM   #3 (permalink)
Awww.... F.
Thanks for the info, Mike.
JstAneon is offline
Old 04-13-2006, 03:09 PM   #4 (permalink)
AcidLotus's Avatar
AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus
it's actually a good thing. So far, I have not heard of any TSXs getting stolen. The DBW makes it a bit more difficult in that RSXs are starting to get stolen since you can put a Kpro ECU in it and bypass the ignition.
2005 TSX 6MT + Navi
AcidLotus is offline
Old 07-26-2006, 07:22 PM   #5 (permalink)
Car: 2000 Accord 2dr
Mods: Springs, shocks, sway bars, strut bar, full body kit, all honda options--getto radio delete :)
MrChad is an unknown quantity at this point
I have a buddy that makes TSX keys for way less then $150...
http://members.cardomain.com/mr_chad
2000 Accord EX Coupe 5-speed
Eibach Prokits springs; Koni Sport Shocks (yellow); BBS RK [17.5 lbs-ET+46] (225/45/17" Potenza RE050A-pole positions); WingWest type W / Honda Optional body kit; Kenwood MP628 Sirius SAT radio HU; Pioneer TS-A6960R rear deck; Ingalls Rear camber-toe kit; TL/CL-S sway bars-strut bar; Prelude SH shifter; TL-S leather wheel; '01 Leather center console; V6 Homelink added; 5000K - 9006 HID's; Hawk HPS brake pads 4-Sale: 18" RacingHart M5 Rims w/tires PM for details
2004 TSX non-Navi Sport Shift
Redline Tuning Quick Lift hood struts; Kenwood KCA-R70FM controller w/ Sirius SAT radio; '03 Accord key mod; 55%F-20%R Tint
MrChad is offline
Old 11-30-2007, 10:05 PM   #6 (permalink)
triple si's Avatar
Car: 02 RSX-S
Mods: Stock
triple si is a jewel in the roughtriple si is a jewel in the roughtriple si is a jewel in the roughtriple si is a jewel in the rough
not good news. i just bought my rsx to aviod problems with gettin it stolen.... *%&#ing THIEVES!
and yes as stated above the key has a chip in it. i verified that when i called the dealer about my rsx.
00 SI :: 11/7/07 :: Stolen & Stripped
triple si is offline
Old 01-12-2008, 11:20 PM   #7 (permalink)
Car: 94 Del Sol SI
Mods: Just a cat back for now.
Effilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphereEffilcdar In the rep troposphere
Yes the keys have a chip in them. To be clear in almost all dealerships it is not actually the key that gets programed but the ecu. The dealership uses a computerized interface to tell the ecu what key chips to allow to start the car and which ones not to. The system is called immobilizer and is the reason a green somewhat key shaped indicator flashes on your dash when you turn the car on. You can get a copied key without the chip to lock and unlock everything in the car including the doors and glove box and even turn the ignition on but the plugs won't fire (actually I don't remember if it disables spark or injectors) so the engine won't run. It would require two different accomplices working in a dealership and some expensive equipment to get a key to work for stealing a immobilizer equipped car and even if you did it would give away who did it.
Effilcdar is offline
Old 01-13-2008, 10:46 AM   #8 (permalink)
AcidLotus's Avatar
The immobilizer is separate from the ECU.
2005 TSX 6MT + Navi
Old 01-13-2008, 08:09 PM   #9 (permalink)
Car: 94 Del Sol SI
Congrats for knowing that. But even though it is a separate unit it doesn't function that way. Its still programed through the DLC. If I remember correctly it is part of the F-can network but to be honest we don't really have enough problems with it to study it in detail. about the only thing in the system that ever needs to be replaced is the receiver (a ring that goes around the ignition key hole and talks to the chip in the key) and even that going bad is somewhat rare.
