JDM B16 complete swap w/lsd
I am contemplating going H22 so just seeing if there's any interest in this swap I have. I have not even installed this motor since I bought it from Japan Motor Import last year. This is basically a complete swap for 96-00 Civics. Here's what's included:
JDM B16A complete longblock (170hp stock)
JDM factory LSD transmission
NEW! AEBS Typhoon intake manifold
NEW! AEBS 65mm throttle body, port-matched to i/m, inlet tapered
NEW! 8lb aluminum flywheel
NEW! TCS 6-puck sprung hub clutch good to 400hp
NEW! Megan Racing 4-1 header with 2.5" collector
NEW! starter
Distributor
midshaft & axles
alternator
Mugen knock-off valve cover (blue)
NGK plug wires
shift linkage & mount brackets for all 96-00 Civics (including CRV a/c bracket to maintain your stock compressor)
OBD1 P72 with Phearable.net B16 basemap chip
distributor, injectors, alternator are all OBD2 now. Those can easily be changed if you want it for 95-earlier models. Only needs an exhaust manifold or header.
This swap with LSD costs $2550 + shipping from Hmotors, and you are getting all the EK mounts, OBD2 stuff, and at least $900-1000 in extra new parts already installed. $2500 firm. It would be best if you're in the Michigan or midwest area and are able to pick it up.
