Mods: B16 swap, GS-R tranny, type r cams, type R clutch, XTD flywheel and clutchplate, dc header, black SI rims, DC Sports front upper strut bar, dropped on some Tenzo's, Tenzo intake, Skunk 2 intake manifold, twin loop exhaust, brand new dover white pearl satin paint!
if you want speed you have to have money. first decide if you want naturally aspirated, then start building but dont start buying stuff and find out later that you spent your money on stupid stuff. Start with the motor, clutch, then move on up to bigger and better. Have a goal and an idea of what you want to do then go from there. Speed is a question of money!
You laugh at me because I'm different, but I laugh at you because you're all the same!
Striving2bdBest
Rocking the B16 w00tz
Also, get a better motor, the 1.5 and 1.6 are cheaper to build but there is more power in B series motors... I have a 95 coupe ex 1.6 sohc vtech and it is weak compared to my b16 94 si...
Striving2bdBest
X2
Striving2bdBest
Originally Posted by shameer
wat do u need to convert from an auto tranny to a manual one......i aleardy got the manuel tranny.......wat else od i need???
well now you need to convert the entire car. Pedals, cables... etc the cluster can be used but you have to have a conversion wireing harness I think... The block is cheap maybe about 600.00 check out the classifieds.. there are a ton for sale often
Striving2bdBest
