Mods: 1998 b18b1 with stage 2 clutch and Limited Slip LS tranny
I just bought a 95 civic with a b18b swap. Everything was done before i bought it, its obd1 and has power steering, ac, and all that good stuff. the only thing wrong with it is the suspension. and the problem is i have to use it to deliver pizza every day. could someone tell me what exactly i should have for front suspension, such as bushings. thanks.
This is probably the wrong place for this question.
But the 5/6th gen stock suspension is pretty damn solid if you want long lasting no worry suspension without the head ache of camber kits and wheel rubbing etc etc.
Ok so the wiring thing is pretty much whats been keeping me from doing a swap into my ej8...
So if i get an OBD2 LS swap then the engine harness will plug right into the stock harness in the engine bay?? other than modifying those couple of things for the o2 sensor ect.
__________________ Myspace http://www.myspace.com/mr_ej8 89 Crx Si - Sold
95 Civic Dx - Sold
97 Del Sol Si Turbo - Sold
94 Civic Hatch - Sold 97 Civic Ex - Current ride
no, you'll use the harness that's already in your car. most of the plugs are in near the same location, with the exception of the few mentioned above that will just need to be extended. other than that, it's nearly a plug&play affair.
__________________ buy my turbo stuff!BUY my RIMS?
-Proverbs 16:31
- Martina Navratilova
Ok got it, so ill use the Y8 harness and swap it over to the B18 motor and extend the few plugs that are short and its a done deal then?? Sounds alot easier then i was thinking.
95 Civic Dx - Sold
yes, it's pretty easy. there's only 1 or 2 plugs that aren't the same between the harnesses, which isn't a big deal. then the extension of a couple wires, and you'll have your vtec solenoid plug left over.
-Proverbs 16:31
sweet thanks alot. looks like ill be saving over winter for an LS swap and more turbo parts.
95 Civic Dx - Sold
Car: '94 auto Civic EX (2dr), '94 5sp LX (4dr)
Mods: EX: stock. LX: SRI, exhaust. Soon Y8 and B&M shifter, maybe EX trans.
Originally Posted by Zeko
i have a D16Y7 engine and im planing to put b18c1 inside so is it the same process?
It should be the same. The only difference between the D16Y8 and Y7 is that the Y8 has VTec and the plug for it. I work on 5th gens, so I do not know where the oil pressure sensor is, if it has one. If it does, reroute it if need be.
i can't speak to that as i've not done that swap. there's plenty of information here from people who have though, and it should be fairly easy.
-Proverbs 16:31
