D16ZC VS D16Z6 - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 11-29-2008, 07:59 PM   #1 (permalink)
sc15's Avatar
Car: 1994 Honda Civic VX
Mods: d16zc, Eagle crankshaft, eagle sleeves, fjr rods, 40 over vitara pistons, blox IM, 800cc bosch injectors, port and polish, bisimoto valvetrain, bisimoto camshaft, vision adjustable cam gear, Ironman stage 4 clutch, T4 Garret turbo, mishimoto intercooler, wet nitrous, neptune
sc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problemsc15 has a Rep problem
tech wrench D16ZC VS D16Z6
I want to do an engine swap to my 95 civic dx. I just bought 2 engines and need to know which one would be better to put in. one is a D16ZC Sohc Vtech. the other is a D16Z6 punched out 60 over with je racing pistons. it is also ported and polished. Which one would i be better off with? and what's a 60 over? prob the stupidest question you've heard but i need to know all the stuff since i just got a good deal without knowing what it is haha.
1991 Lincoln Town Car - Sold
1989 Jeep Cherokee Laredo - Sold
1995 Honda Civic DX - Sold
1995 Honda Civic EX - Sold
1994 Honda Civic VX - Project/daily driver
1986 Chevy Camaro - Project
www.myspace.com/crazytemptations
sc15 is offline
Old 11-29-2008, 08:05 PM   #2 (permalink)
solman's Avatar
Car: 05 Cobb stage2 wrx
solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?solman Why haven't you checked into rep rehab yet?
60 over means the cylinder was bored .06" bigger.
check me out www.myspace.com/solman94
solman is offline
Old 11-29-2008, 08:06 PM   #3 (permalink)
sc15's Avatar
is that alot?
sc15 is offline
Old 11-29-2008, 08:29 PM   #4 (permalink)
solman's Avatar
Thats about as big as you can go without sleeving the block. the bigger you go the more power you can get but the engine will run hotter.
solman is offline
Old 11-29-2008, 09:06 PM   #5 (permalink)
Car: 1992 civic
Mods: d16z6,megan exhaust,egale rods,pistons,crower cam,valve springs,retainers,ferrera valves,venom cam gear,injen cold air,skunk2 intake,megan coilover dampers,welbro 255 fuel pump,aem fuel rail,venom injectors,tanable strut bars front/rear,b pillar bar,type r seats, momo steering wheel,auto meter gagues,flik blast 15in rims with toyos
pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic pivot92civic
does the d16z6 have a vtec head?
pivot92civic is offline
Old 11-29-2008, 10:20 PM   #6 (permalink)
Kabooki's Avatar
Car: 96 Del Sol SiR TT
Mods: can kiss my butt!
Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?Kabooki you're still here?
Yup. Sounds like thats gonna be your best bet.
Kabooki is offline
Old 11-29-2008, 11:04 PM   #7 (permalink)
sc15's Avatar
the z6 is a vtech. i was just buying a tranny but the guy asked me if i wanted the engines to take them so i did. so i'm just trying to know all i can about them.
sc15 is offline
Old 11-29-2008, 11:12 PM   #8 (permalink)
sc15's Avatar
so which one would be better? i am planning on having it turboed... dude said the Z6 is ready for 22psi. just needs rod bushings.
sc15 is offline
Old 11-30-2008, 01:17 AM   #9 (permalink)
Car: 1992 civic
i would check out the z6 first before you turbo it do the swap and run it n/a for a little bit and break the motor in and if she dont smoke any and no other problems happen then turbo it and to make it a reliable car i wouldnt boost more then 15lbs becuz i had the same motor little different parts and i was boosting 20lbs and blow a rod out the side of my block after 4,500 miles and not even boosting most of the time
Old 11-30-2008, 01:46 AM   #10 (permalink)
sc15's Avatar
im gonna do aftermarket rods if i end up using the z6. it already has pistons and its port and polished. i'm trying to get the most power out of my car. and i will probably drive it for 3,000mi before throwing the turbo back on. i'll also start off at 8psi to be safe and work my way up. would that work? how hard is it to do the z6 swap?
sc15 is offline
Old 11-30-2008, 10:40 AM   #11 (permalink)
sc15's Avatar
I've been doing alot of research and i'm leaning more towards the Z6 right now
sc15 is offline
Old 11-30-2008, 10:50 AM   #12 (permalink)
Car: 1992 civic
its really not that hard every thing is the same as like if you had a b7 motor mine when in with no problems, but you got to get the ecu for it just get one out of a 92-95 ex or si, it will work or just do what most kids do and hook ur vtec up to a button on ur shifter
Old 11-30-2008, 11:00 AM   #13 (permalink)
sc15's Avatar
yeah he's giving me a P28 ECU so i think that will work. People are saying that the ZC is hard to find parts for...
sc15 is offline
Old 11-30-2008, 11:07 AM   #14 (permalink)
Car: 1992 civic
yeah but i think egale has rods for and crower makes a cam for it just look you will find parts just think all the intake bolts r the same for all d16s same with fuel rails and everything eles
Old 11-30-2008, 11:12 AM   #15 (permalink)
sc15's Avatar
i was also thinking that but the Z6 is already started. i just need rods. and you have egale so i'm guessing they are working good for you. i'll probably end up building them both and selling one or just keep it as a spare.
sc15 is offline
