ecu problem - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 09-21-2008, 11:30 AM   #1 (permalink)
revtwored's Avatar
Car: 97 civic ex
Mods: intake, exhaust, coilovers, rims, tail lights and headlights
revtwored revtwored revtwored revtwored revtwored revtwored revtwored revtwored revtwored revtwored revtwored
tech wrench ecu problem
i bought a 97 civic ex and he was saying he swapped the engine to d16y8 (i dont know why he would waste his time doing a swap like that) but if i get on it i can only rev to 5g and the car will cut out and not revlimit cut out but totally bog out and wont even try to accelerate but when i shift i can go again only to 5g and it never does it in 1st gear but everyother gear. is this an ecu problem???
revtwored is offline
Old 09-21-2008, 11:32 AM   #2 (permalink)
Olde School Ricer
Car: 89crx
might be
yellowrexsi is offline
Old 09-21-2008, 12:33 PM   #3 (permalink)
hndacvcsi's Avatar
Car: 94' panda coupe...
Mods: Lots of insta-rice!!!!!
hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?hndacvcsi you're still here?
ok im kinda confused because a 97 civic ex comes with the d16y8 from the factory. sounds suspect to me.
Originally Posted by 91rex-si View Post
fuck b and z...dirty d all the way
Flat Black is not a choice, but a mandatory requirement of sleeperism(my new word)
I will say it once more for the ricers that grace this site and i see on the road. A pep boys muffler, Rims, and 12's in the trunk, DO NOT make your car "Modified"!!!!
hndacvcsi is offline
Old 09-21-2008, 01:06 PM   #4 (permalink)
revtwored's Avatar
Car: 97 civic ex
he said it had the non vtec and he wanted v tec so it didnt have the y8 in it and he said the motor was out of a 99 or 00 he couldnt remember... different ecu in those years do you think?
Old 09-21-2008, 01:25 PM   #5 (permalink)
Super Nazi Mod
RedWabbit's Avatar
Car: 81 Rabbit 81 Rabbit Pickup 84 Vr6 Rabbit Convertible 97 Accord 00 Jetta VR6 97 Audi A4 1.8t
RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!RedWabbit Bow down before me!
1 of 2 things is going on
1 he lied to you and your an idiot for believing him
2 he lied to you and your an idiot
97 ex came with the y8 if it didn't come with a y8 and he swapped one in then its not a ex its that simple.
1 the oil pressure solenoid will not allow vtec to engage if it is low on oil.
2 its gonna be tough but check the oil
3 the only difference between obd2a and obd2b are the ecu connections. all the wiring on the engine is the same.
4 no this should not be an ecu problem
5 if he swapped the engine he might have done a shitty job check his work
6 if what your really trying to say is once it hits 5000rpms it still accelerates but has no balls like it just fell flat on its face. then your vtec solenoid is not engaging
7 2 things can cause this problem
a: vtec not wired in properly if hes saying it did not have a y8 and he swapped one in(therefore you don't have an ex) this is most likely the case.
b: the vtec solenoid is bad and needs to be replaced
so right now you need to get your facts straight before you even continue. then go over this list and figure out which one best suits the situation
Originally Posted by Darkness View Post
pshh you're obviously new to woman and vaginas....bitches will nag and vagina's will eventually sag.....
it's better to lease in this situation than it is to own
RedWabbit is offline
Old 09-21-2008, 02:14 PM   #6 (permalink)
revtwored's Avatar
Car: 97 civic ex
1 the title says ex 2 i never said its gutless after five i said it pretty much shuts down even if i hold the pedal to the floor rpms go down 3 vtec works fine in 1st and works when im not driving it hard 4 i just changed the oil three days ago thinking that might have been the problem so that elimanates that... v tec still work just not when driving hard so what now???
Old 09-21-2008, 02:33 PM   #7 (permalink)
Super Nazi Mod
RedWabbit's Avatar
how much fuel do you have in your gas tank?
Old 09-21-2008, 03:19 PM   #8 (permalink)
hndacvcsi's Avatar
you have a hack wiring job is what you have i bet he has the wrong ecu. if it had a non-vtec motor in it first then it had a non-vtec ecu. check the code on your ecu, the right one is p2p i believe i may be wrong though, id you have to convert to obd1 and p28 that bitch
Old 09-21-2008, 03:26 PM   #9 (permalink)
revtwored's Avatar
Car: 97 civic ex
i have a full tank im not new to hondas... three swaps in accords and six swapps into civics... i believe its the wrong ecu i was just trying to get opinions
Old 09-21-2008, 03:32 PM   #10 (permalink)
Olde School Ricer
Car: 89crx
what ecu is it
is it throwing any codes
yes you are new to hondas, anyone with any experience could have had this trouble shot in the time it takes to sign up for this forum
Old 09-21-2008, 03:35 PM   #11 (permalink)
revtwored's Avatar
Car: 97 civic ex
no im not new to hondas i just wanted to see what others thought because it nice to have others inputs i never said i was an expert either...
Old 09-21-2008, 03:36 PM   #12 (permalink)
Olde School Ricer
Car: 89crx
I just asked you 2 questions
Old 09-21-2008, 04:02 PM   #13 (permalink)
revtwored's Avatar
Car: 97 civic ex
ok here ya go..........
OEM Part # Our Part # Applicable For Make, Model, Submodel, Year
37820P2PA02 ECU1103563 HONDA, CIVIC, DX, 1996
More Info
37820P2PA02 ECU149853 HONDA, CIVIC, LX, 1997
More Info
37820P2PA02 ECU150619 HONDA, CIVIC, HX, 1996
More Info
37820P2PA02 ECU151244 HONDA, CIVIC, EX, 1996
More Info
37820P2PA02 ECU152432 HONDA, CIVIC, DX, 1997
More Info
37820P2PA02 ECU153580 HONDA, CIVIC, CX, 1997
More Info
37820P2PA02 ECU153831 HONDA, CIVIC, EX, 1997
More Info
37820P2PA02 ECU154828 HONDA, CIVIC, LX, 1996
More Info
37820P2PA02 ECU157130 HONDA, CIVIC, HX, 1997
More Info
37820P2PA02 ECU199989 HONDA, CIVIC, CX, 1996
More Info
37820P2PA31 ECU152862 HONDA, CIVIC, CX, 1997
More Info
37820P2PA31 ECU153346 HONDA, CIVIC, CX, 1996
More Info
37820P2PA31 ECU153768 HONDA, CIVIC, LX, 1996
More Info
37820P2PA31 ECU154900 HONDA, CIVIC, LX, 1997
More Info
37820P2PA31 ECU155692 HONDA, CIVIC, HX, 1996
More Info
37820P2PA31 ECU156149 HONDA, CIVIC, EX, 1997
More Info
37820P2PA31 ECU156197 HONDA, CIVIC, HX, 1997
More Info
37820P2PA31 ECU199009 HONDA, CIVIC, EX, 1996
More Info
37820P2PA31 ECU199872 HONDA, CIVIC, DX, 1997
More Info
37820P2PA31 ECU199879 HONDA, CIVIC, DX, 1996
More Info
37820P2PA34 ECU176032 HONDA, CIVIC, LX, 1998
More Info
37820P2PA34 ECU178921 HONDA, CIVIC, HX, 1998
More Info
37820P2PA34 ECU179737 HONDA, CIVIC, CX, 1998
More Info
37820P2PA34 ECU179780 HONDA, CIVIC, EX, 1998
More Info
37820P2PA34 ECU180603 HONDA, CIVIC, DX, 1998
More Info
37820P2PA34 ECU186158 HONDA, CIVIC, GX, 1998
More Info
37820P2PA72 ECU1101137 HONDA, CIVIC, CX, 1996
More Info
37820P2PA72 ECU151801 HONDA, CIVIC, HX, 1996
More Info
37820P2PA72 ECU151839 HONDA, CIVIC, DX, 1997
More Info
37820P2PA72 ECU153516 HONDA, CIVIC, EX, 1997
More Info
37820P2PA72 ECU153624 HONDA, CIVIC, HX, 1997
More Info
37820P2PA72 ECU153679 HONDA, CIVIC, LX, 1996
More Info
37820P2PA72 ECU154523 HONDA, CIVIC, DX, 1996
More Info
37820P2PA72 ECU155139 HONDA, CIVIC, CX, 1997
More Info
37820P2PA72 ECU157008 HONDA, CIVIC, LX, 1997
More Info
37820P2PA72 ECU198451 HONDA, CIVIC, EX, 1996
More Info
37820P2PA81 ECU1100343 HONDA, CIVIC, HX, 1997
More Info
37820P2PA81 ECU1100947 HONDA, CIVIC, LX, 1996
More Info
37820P2PA81 ECU150960 HONDA, CIVIC, DX, 1997
More Info
37820P2PA81 ECU152624 HONDA, CIVIC, EX, 1996
More Info
37820P2PA81 ECU153255 HONDA, CIVIC, DX, 1996
More Info
37820P2PA81 ECU153484 HONDA, CIVIC, EX, 1997
More Info
37820P2PA81 ECU154622 HONDA, CIVIC, CX, 1996
More Info
37820P2PA81 ECU155181 HONDA, CIVIC, HX, 1996
More Info
37820P2PA81 ECU156672 HONDA, CIVIC, LX, 1997
More Info
37820P2PA81 ECU198081 HONDA, CIVIC, CX, 1997
More Info
37820P2PA84 ECU1107014 HONDA, CIVIC, CX, 1998
More Info
37820P2PA84 ECU1107596 HONDA, CIVIC, LX, 1998
More Info
37820P2PA84 ECU176765 HONDA, CIVIC, EX, 1998
More Info
37820P2PA84 ECU177766 HONDA, CIVIC, DX, 1998
More Info
37820P2PA84 ECU181082 HONDA, CIVIC, HX, 1998
More Info
37820P2PA84 ECU187451 HONDA, CIVIC, GX, 1998
More Info
here is for those who dont know that there is many different ecu that they use for years and styles like ex hx dx etc... and i have p2pa32 and i dont see that anywhere on this list so im guessing its the wrong ecu...
Old 09-21-2008, 04:07 PM   #14 (permalink)
hndacvcsi's Avatar
so just get a p72 in there and see if it fixes the problem
Old 09-21-2008, 04:39 PM   #15 (permalink)
Super Nazi Mod
RedWabbit's Avatar
Originally Posted by yellowrexsi View Post
what ecu is it
truth
and he still didn't answer one of them
I believe your wiring needs to be gone over carefully. I think he fucked it up somewhere. probably when he repinned the ecu
