Old 05-21-2008, 10:13 PM   #1 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?
idle problem...again yes i searched
ok i been messing with this for a few weeks now 94 EX d16z6.....the idle would drop real low around 200 rpm then bounce to around 500only when warm, when cold it ran as it should...ok so i checked my electrical connections, then vaccum lines, then finally pull the IAC it looks normal...just incase i replace the iac with a known good iac....still get the rough/flux idle but driving it around for a few weeks i notice it really only gets stumbly when im on the brakes at a stoplight the brake vac lines are ok, the booster has no visible cracks, i am at a loss... do i need to burp the coolant? like maybe there is enough of an air pocket in there to cause the IAC to cool and reheat causing this?
Anomoly is online now
Old 05-22-2008, 12:02 AM   #2 (permalink)
Car: 2003 Civic EX
Mods: K & N typhoon air intake, custom 2.25' exhaust, custom headers wrapped up... looking to turbo soon... with a write up!
poopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep tropospherepoopflingr1 In the rep troposphere
ya, try that... either that or try replacing the hoses and see if there is one that just isnt holding up when the car turns on and runs a long time... like, maybe it collapses under the load?
hmmm...
poopflingr1 is offline
Old 05-22-2008, 03:40 PM   #3 (permalink)
93HondaMan's Avatar
Car: 2006 Dodge Ram 2500 CTD(Weekend Warrior)TORQUE UP THE ASS!!!93 Civic LX (Daily Driver)
Mods: AEM intake,Edelbrock Header,NGK B18 Spark plug wires,Drop kit,17" Rota Torque wheels,Smoked LED tails,Smoked Turn Signal lamps,8000K HID's Hi/Low kit
93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem93HondaMan has a Rep problem
Try adjusted the Idle control on the throttle body.This might possibly work for you as it did for me.
93HondaMan is offline
Old 05-22-2008, 06:32 PM   #4 (permalink)
Dark Wind
Mods: both stock
nope didnt work, still have the same problem
Old 05-22-2008, 06:35 PM   #5 (permalink)
93HondaMan's Avatar
Did you turn the flat head screw or the nut under the spring/Flapper arm?
Old 05-22-2008, 06:38 PM   #6 (permalink)
Super Moderator
Car: 89crx
Sounds stupid, but how is your alternator and battery
Low voltage will give you these signs
also, I would burp the coolant
Originally Posted by got-vtec?
Would it be safe to go about 180-190 mph on the street in a lightened crx.
yellowrexsi is offline
Old 05-22-2008, 06:40 PM   #7 (permalink)
Super Moderator
Car: 89crx
this might help, my favorite sticky
Troubleshooting Idle Problems
Old 05-23-2008, 02:54 PM   #8 (permalink)
Dark Wind
Mods: both stock
argh im an idiot.... i just made sure all those connections were tight, i didnt think to bust out the multimeter, although my car stereo has a function where it can display voltage, car off it shows 12.0 running it gets around 14.4... dunno how accurate the deck is though
Old 05-23-2008, 03:58 PM   #9 (permalink)
Super Moderator
Car: 89crx
voltage sounds good, time to look other places
Old 05-23-2008, 11:56 PM   #10 (permalink)
ltlblkcvc's Avatar
Car: 99 Civic
ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?
no I would actually test the alt. not just use the radio. check the grounds on the water neck and the coolant temp sensor. saturn had a big problem with this when its 20 buck plastic part went bad
Originally Posted by WVU97GS-R View Post
Originally Posted by HonduhDave
By no means do I think I'm a genius
Originally Posted by Snoopy
ltlblkcvc is offline
