when my car is parked it revs its self between 1000 and 1500 rpms .....if any can identify this problem for me and can tell me how i can fix it.....it would be greatly appreciated...
Mods: K & N typhoon air intake, custom 2.25' exhaust, custom headers wrapped up... looking to turbo soon... with a write up!
Originally Posted by Dthekk1989
ok guys thanx for the help...what coolant do i need to check?
the coolant.... in ur radiator? lol.
look at ur "overflow" bottle next to ur radiator and see where the coolant level is. I think its ur IAC or something along those lines, but u never really know.
Mods: Del Sol Si - B16 T3/T4 Turbo, Tsudo Exhaust, No cat, 450cc. Phoenix Gold MaxX Carbon Fiber Subs, 2000watt amp.
Check to make sure that all of the hoses/lines that are connecting to the intake manifold are secure connected on both ends. If they are, then most likely you have a bad/dirty Idle Control Valve located on the back of the Intake Manifold. Don't forget to check your coolant reservoir level and oil while you're at it.
hey, also check the strength of the tubes.
gently squeeze the tubes under ur hood to make sure none are soft or are cracking... either will cause a vacuum leak and may really mess ur car up if it is something important.
well i took off the idle control valve and cleaned it...but im still having the problems....i checked my hoses...and the hoses are fine..its frustrating...i think the valve might be junk but idk...
