Old 04-27-2004, 08:59 PM   #1 (permalink)
Car: 03 Dodge SRT4
Mods: 03 SRT4 w/ short ram w/ K&N, Wastegate, Forge BOV,Exhaust Depot hardpipe,MSD Coil, MSD plug wires,3" NW DP w/ e-cutout, Autometer 30/30 Cobalt boost gauge
92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life92HondaCivic You need a life
Idling problem
OK i dont know if i posted this here yet or not but my car was having an idling problem. I thought at first it was just the IACV, had that replaced didnt fix the problem; took it to another mechanic and he couldnt figure out what was wrong with it. He checked for vacuum leaks and wasnt it, i put in some injector cleaner and that didnt help, he made sure my coolant is ok and it is. So its not
my injectors
coolant
vacuum leak
IACV
What else could be causing my car to idle surge? The guy at B&K Imports the second mechanic i took it to seems to think its the VAFC i had installed. Could my VACF be causing my idle surging? I have never heard of that happening. What my car does is idle real weird when im sitting still ie. like at a stoplight. When im goign the car doesnt seem to do it and the car seems to run fine. The idle surging has become worse. It used to stop after my car warmed up after runnign it for a lil bit but now it constantly does no matter how long i drive.Every once in a while though it wont do it.
92 dx 4-door ex motor/tranny w i/e/NX55 shot RIP
95 prelude Si-bolt-ons and 50 shot-SOLD
93 Nissan 240sx SE 5spd bought 4/1/06- i/e/MSD :SOLD:
89 CRX HF JDM DOHC ZC I/H/E,CF hood,fully gutted SOLD
91 teg- 99' LS motor, B16 tranny I/H *Traded*
90 Nissan 240sx Sr20DET swap down at the moment
92 civic h22 swap
89 crx D16y7-wrecked
89 240sx RB20DET swap-SOLD
my new toy 03 Neon SRT-4 w/ catch can, ED coldside upipe, short ram w/ K&N, Tein springs, 3" NW's DP, MM inserts,AEM Uego wideband,Autometer colbolt boost gauge,wastegate,Forge BOV, MSD plug wires, MSD coil,Maxxfab 3"02 housing,mapclamp
Domestic Owner's thread; check in people
http://www.superhonda.com/forum/showthread.php?t=280306
92HondaCivic is offline
Old 04-29-2004, 02:07 AM   #2 (permalink)
Iron Monk
Car: Maxima
Mods: working stage
xdannyx25 will become famous soon enoughxdannyx25 will become famous soon enough
make sure all the hoses are clean, and the throttle body... pcv........ also your tps
But what do I know?!
xdannyx25 is offline
Old 04-29-2004, 02:23 AM   #3 (permalink)
Car: Dc2 Gsr 94
Mods: Bolt-on + type-r tranny with lsd
civic_98_4door is just really nicecivic_98_4door is just really nicecivic_98_4door is just really nicecivic_98_4door is just really nice
Open your rad and let it warm up a bit and fully load it until theres is no more buble and close it this should do it.
civic_98_4door is offline
Old 04-29-2004, 08:57 PM   #4 (permalink)
Car: '05 RSX-S
pwrdbykmfdm is an unknown quantity at this point
wassup, i had the same prob, and it seems like alot of 92-95 civic have this problem. this is what it was and how i fixed it for free.
my intake manifold gasket was bad. when your car warms up it will expand and close the gaps, so i would spray sme intake cleaner along your intake manifold gasket while your car is running, if the surging stops or if there is any change in idle then you need a new gasket, but heres the free/cheap way to fix it and it will last a long time.
smear a bunch of silicone gasket sealent all over around the intake mani gasket to seal it up, let it dry and your all fixed.
my car was doing that same thing and idle, it would surge from about 600rpm to 1200rpm, now its at a nice 500-600rpm all the time.
hope this helps!
pwrdbykmfdm is offline
Old 04-30-2004, 03:35 AM   #5 (permalink)
Car: 03 Dodge SRT4
problem fixed
I found out what is was. I was told it was my fast idle.
92 civic h22 swap
Old 05-02-2004, 06:35 PM   #6 (permalink)
Car: Dc2 Gsr 94
???? fast idle we can have that on a honda. please explain
Old 07-16-2004, 09:27 PM   #7 (permalink)
Car: '05 RSX-S
i know its a little late, but...
fast idle is the little flathead screw on your TB. i am pretty sure all it does is determine how fast your car idles, hence the name 'fast idle' lol.
Old 08-23-2004, 01:10 PM   #8 (permalink)
Car: 1995 Del Sol Si
Mods: Engine Block: B18B1 W/BG. Bearings: Clevite Tri-Metal MB&RB. Oil Pump: Type-R. Underdrive Pully: Forum. Rods: Eagle H-Beam. Pistons: CP-Pistons 10.5:1 Compression. Cylinder Head: B16A Polished. Valve Train: V,S,R Skunk2. Cams: JDM Spec B16A Cams. Intake Manifold: AEBS. Throttle Body: Holly 62mm. Fuel Rail: Stock. Fuel Pressure Regulator: B&M. Intak
NutromiX has a little shameless behaviour in the past
Hello,
I have the same exact problem but its not my TPS its not my IACV its not the " Fast Idle Screw " Hell I went and got the book. It said it could be the EGR but I have no idea where the hell that is. I had the problem on my other car but that was a vacume leak that I fix. I have no Idea what this is. Can any of you help !
NutromiX is offline
Old 08-23-2004, 03:21 PM   #9 (permalink)
Car: Honda
Ryocross is an unknown quantity at this point
MAP
Ryocross is offline
Old 08-23-2004, 05:12 PM   #10 (permalink)
GunMetal Member
Car: 2000 Civic HX
Mods: Custom mesh grill (gutter guard!!!), DIY gunmetal headlights, Hella Optilux Driving Lights, Reverse Indiglow Gauges, Del Sol Seats, Type-R Style Quick Shift Auto Knob, "Racing" Pedals (haha, "Racing")
gmusquiz will become famous soon enough
The fast idle is not the screw on the throttle body, that would be the idle adjusting screw. All the screw does is adjust the idle up or down as you are letting more or less air into the TB. There is a FIA control valve, but that is the fuel injection air control valve to allow more air to the fuel injectors. I had an idle fluctuating problem coupled with hard cold starts, but all that was was two connectors were wrong from the ECT and VTEC pressure switch. Switched those and everything's fine.
Originally Posted by jdm_kid
JDM people don't need airbags
gmusquiz is offline
