Originally posted by Requiem
obtw the frame is black, but its made of plastic or something! so basically black plastic and some cheap mesh...
how do you install the new grille?
For the paint. I would say any pricey paint that is for metal. You'll find a few brands at Home Depot. ..and when I say pricey I am just telling you to avoid the .89 or 1.99 cans that won't be as good. Pricey is about $5 at the most. I think the can to paint my headlights was like $3.89
I imagine you have a 6th gen civic
If so, I have the grill and it's pie!
1) Pop your hood and you'll notice about 6 or 8 black plastic screws that hold the bumper in place just in front of the hood latch all across the front end.
2) Remove the necessary amount of screw to remove the stock center piece. Take a flat tip screwdriver and just wedge the center of the screw up and when it pops up, the entire thing comes right out. Takes like 2 seconds for one screw.
3) I believe once you remove the screws you have a clip or two that holds the grill to the bumper that you'll have to remove to get the grill out. You'll be able to tell what's holding the grill in place.
4) Place the new grill into place and put the screws back in. Pie Job!
PS <> I had to leave the two outer screws that hold the grill in place out because when they were in they would cause the bottom to pop out of place. It's because the contour of my grill is not 100% accurate. But, you can't tell the screws are missing and the look is damn Tyte!!!
Let me know if you have any more Q's!
BTW! This is the grill I have: $50 shipped
It's getting a little dull now so I may paint it black sometime....
and I imaigine this is the grill you have:
