ok ok. let me get this straight. you guys think it's the axle seals? but then i heard it was the input axle seals?output seal?hub seals? Differential Seals? Which one is it? And what axle seals do i use? I have a JDM B16a SiR II motor. It should be the same motor from 99-00 Civic Si or Honda Del Sol VTEC motor right. So any of those input axle seals are ok right?
And how hard is it to change the input axle seals? I only hear the intense clunking noise whenever making a U turn or a turn. If i go straight. Cant hear no noise or whatsoever. ANd you can actually feel the clunking noise. It gets really really really bad!!! I get embarass whenever i make a U turn. All the hot babes would look at me. LoLz.
you guys dont think the rear D series mounts got anything to do with it right?
Is there both sides to the Axle Input Seals. Or just one side?
Is the Axle seals showing here in this pix?
