Leaking brake fluid? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 01-13-2003, 12:20 PM   #1 (permalink)
Car: Civic '94
zecro49 is an unknown quantity at this point
tech wrench Leaking brake fluid?
I'm new to cars so people help!!
Got new wheels put on my 94 civic ex put on last week. Guy told me my brake fluid is leaking and recomended a rec & pin change cost about 400 dollars. What is going on? All that I could see was the wheel wells were a little greasy. Should I be concerned? How bad is this?
Appreciate the help!
zecro49 is offline
Old 01-13-2003, 06:31 PM   #2 (permalink)
Administrator
Johnny Tran's Avatar
Car: 2012 Infiniti G37
Re: Leaking brake fluid?
Is your fluid level low under the hood???
12 Infiniti G37
2000 EBP Si
STOLEN 11-21-04
Team OG AKA v00tecsi
Johnny Tran is offline
Old 01-13-2003, 06:36 PM   #3 (permalink)
Car: 1989 hatchback DX
Mods: nuttin yet
89hatch is an unknown quantity at this point
my hatch is leaking fluid to, it only takes like 5 days to drain low enough for my light to come on, does it cost 400 to fix? can i do it myself?
89hatch is offline
Old 01-13-2003, 07:02 PM   #4 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
All depends on what the problem is and where the problem is. I was leaking fluid as well. I just had a loose fitting. 15seconds with a 10mm wrench solved the problem.
kommon_sense is offline
Old 01-13-2003, 07:04 PM   #5 (permalink)
I would do a little more work before I commit to the $400. A blown shock can leak oil. So that could have been from the shock and not the brakes. Watch your brake fluid and see if it leaks.
You may also want to flush the brake system and used a colored brake fluid like ATE Superblue Racing fluid. It'll be a lot easier to spot a leak with blue fluid than clear fluid.
Old 01-15-2003, 02:47 PM   #6 (permalink)
Car: Civic '94
Fluid level under the hood is the same...all that I hear is a grinding sound when I go over 3k rpms before changing gears......
zecro49 is offline
