p0131 code - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 01-28-2008, 07:54 PM   #1 (permalink)
NationsMostWanted's Avatar
p0131 code
low voltage in bank 1 sensor 1. I rechecked my a few times wiring and even tested a second sensor and its still throwing the code after driving. anyone dealt with this code before and some easy solutions.
Im going possible check for an exhaust leak next maybe theres a leak down there
NationsMostWanted is offline
Old 01-29-2008, 10:28 PM   #2 (permalink)
hmmm im still stumped i think theres a TSB on it but cant find out what the solution is. I read it was a exhaust manifold crack...but not sure yet. im going take it off to check tommorrow.
Old 01-30-2008, 02:43 PM   #3 (permalink)
Car: 2003 Accord Ex Coupe
Mods: Huge wing, couple of kanooter valves and oh yes the whipple valve too! Super V-tak, gay stickers, parts that don't work, some mats like Strongman ftl
lowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapylowcivic66 needs rep therapy
replace 02 sensor, they usually throw that code when they are spent from my experience, oh and although they are cheaper do not use a universal 02, buy vehicle specific. Good luck.
Quote: Originally Posted by rnstein69
um, 0 to 60 in 9 seconds? my grandmother can do the moonwalk and still beat you off the line..
http://en.wikipedia.org/wiki/Honda_Civic
lowcivic66 is offline
Old 01-30-2008, 07:38 PM   #4 (permalink)
well what i did was wire both a civic and integra one and still throwing same code....
Old 01-30-2008, 09:41 PM   #5 (permalink)
im going get the sensor tommorrow
Old 01-31-2008, 12:47 PM   #6 (permalink)
j.steimer04's Avatar
Car: 2004 Civic EX 4dr
j.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapyj.steimer04 needs rep therapy
Check the wiring and make sure they are secure inside of the sensor. That was my problem a few weeks ago when mine popped on.
j.steimer04 is offline
Old 01-31-2008, 07:05 PM   #7 (permalink)
same shit i put a new sensor...i looked at the wiring 100000 times and nothing wrong with it from what i seen
Old 01-31-2008, 08:49 PM   #8 (permalink)
its like the car starts of running like a misfire then once the light pops on it seems to run better. i cant figure this shit...wierd
Old 02-02-2008, 09:40 PM   #9 (permalink)
im getting tempted to run the 4 wires directly to the PCM
Old 02-03-2008, 08:08 AM   #10 (permalink)
skullzgsr's Avatar
Car: '00 Integra, '96 Grand Cherokee, '00 civic
Mods: Too many to list
skullzgsr is on a distinguished road
you said you checked the wiring, did you use a dvom and check for resistance values or amp readings on all the wires, and for short to powers and short to grounds? Also check the pigtails of the connectors at both the o2 and at the ecm to see if any are loose. If that checked out fine if you know someone or if you yourself have access to a scan tool check to see what kinda of readings the sensor is putting out. The only other thing is to make sure that that code is definately for the upstream o2 and not the downstream.
Drive it like you stole it...
skullzgsr is offline
Old 02-03-2008, 06:04 PM   #11 (permalink)
i went thru mitchell on demands diag tree and followed it thru with a dvom. ill probably mess with it this monday
Old 02-03-2008, 06:18 PM   #12 (permalink)
Car: 1991 Civic Std Hatch
Mods: 400+HP D16Z6
Chiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problem
Year and model? There's a service bulletin for that code on the GX model only.
1991 Civic Std hatch + D16Z6 + Turbo = 11.2@121
My project car, lots of pics.
Chiovnidca is offline
Old 02-03-2008, 06:25 PM   #13 (permalink)
00 civic ex
Old 02-06-2008, 07:47 PM   #14 (permalink)
hmm after 1 whole day with no code it came right back on....
Old 02-12-2008, 02:18 PM   #15 (permalink)
well today i bypassed the connector and wired the sensor directly to the harness soldered to ensure the connection is not loose. the code still comes on...
