PERFORMANCE SPEED (RESISTOR) FUEL SAVER ...REAL OR FAKE? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Closed Thread
Old 03-30-2009, 07:25 AM   #1 (permalink)
2khonda's Avatar
Car: 2000 Civic EX
Mods: Lambo Kit, Crazy System, Dropped, Cold Air Intake
2khonda is on a distinguished road
I saw this ad on ebay about the Performance chip (resistor) which it attaches to the Intake Air temp circuit in the MAF Harness to trick the ECU (by making it think the air coming into the engine was colder than it really is)into injecting more fuel (to compensate for the apparently higher density)
Could this be possible....?
Has anybody tried this....?
If it works, how much is the difference.....?
Here is the actual ad........
eBay Motors: HONDA CIVIC 1992-2007 PERFORMANCE SPEED CHIP FUEL SAVER (item 250398322777 end time Mar-30-09 13:09:02 PDT)
2khonda is offline
Old 03-30-2009, 07:57 AM   #2 (permalink)
Cypher Wave
CBags04's Avatar
Car: 99 Lude
Mods: Flux Capacitor
CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?CBags04 you're still here?
So, let me get this straight, more fuel, same amount of air, and you think you are going to make more power?
Want the economy to get better?
But when a long train of abuses and usurpations, pursuing invariably the same object, evinces a design to reduce them under absolute despotism, it is their right, it is their duty, to throw off such government, and to provide new guards for their future security.
CBags04 is offline
Old 03-30-2009, 09:40 AM   #3 (permalink)
Cypher Wave
ATISTANG's Avatar
Car: 79 Yugo
Mods: Fuzzy dice hanging in the mirror, chrome hub caps, oversized waabaa valves
this used to be a trick in the early days of electronic fuel injection, but it never really worked.
the idea is the ecu will think the air is colder, so it will send more fuel, and some will up the timing a bit. 99% of the time you lose gas mileage and hp. what a lot of people did before there were options to tune an ecu is used this when using a power adder such as a turbo or nitrous so that the engine wouldn't lean out.
basically you are going to spend money to make your car run worse
ATISTANG is offline
Old 03-30-2009, 12:40 PM   #4 (permalink)
EnJoiThaRex's Avatar
Car: GueSs
Mods: NoNe
EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?EnJoiThaRex Why haven't you checked into rep rehab yet?
X2..There are alot of things the aftermarket offers car owners just to make money.
1988 Honda CRX D15B2 w/MPFI swap: pacesetter headers, tanabe 2 1/4 exhaust system, ZC transmission, B&M short shifter, "aftermarket" intake, tanabe lowering springs (sold)
1990 - Redtop Sr swapped Nissan 240sx-
2003 Mercury sable-wrecked
2000 Ford Focus ZX3
2000 Dodge Neon
2000 Ford Focus Wagon
EnJoiThaRex is offline
Old 03-31-2009, 05:21 AM   #5 (permalink)
cam043's Avatar
Car: 04honda civic dx
Mods: who mods a DX??
cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?cam043 you're still here?
Before i even clicked into this thread i already knew that Ebay was in tha first sentence and that the OP was a Newb
i kno tha words in tha ad make it look tempting ta buy but DONT DO IT!!
Proud supporter of teh Jimmy Hat......and ur mom
cam043 is offline
Old 04-01-2009, 06:25 PM   #6 (permalink)
Serj22's Avatar
Car: 2004 Pontiac Vibe
Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?Serj22 Why haven't you checked into rep rehab yet?
Everything liek that on EBAY is crap. Pure and simple. I watched a test of all that Ebay crap on powerblock and they tested that intake turbine thing, the magnetic spark plug rail, and the ECU re-mapper auto tuner, and some other stuff, and every single thing reduced the power in the car, by 10 to 12hp in some applications, which is an incredible amount of power loss. The "magnetic" thing melted onto the valve cover of the truck and caused a fire, and the "ECU chip" was actually just an LED with a resistor in it to not blow the LED. IT had a power and a ground wire, and then a yellow wire to connect the device to a wire only on when "accessory" is selected - this is the simplist wiring cicuit for a light, but you were meant to belive that it somehow controlled a pice of the ECU. It cost $150 off EBAY with $8 shipping and was literally just a light, they took it apart and it was just a green LED with a resistor and something that looked like a microchip, but it wasn't actually attached to anything.
They tested a bunch of other stuff and said that basically, anything you see on Ebay or Amazon that fills in the name of the car, I.E: "the best performance upgrade for the 1993 HONDA CIVIC..." where it capitalizes the exact name of your car is a load of shit. "Best upgrade in power magazine for the 1923 HONDA CIVIC SI" IT will not usually matter what year you type in, it all advertises the same. Anything that seems too good, and too cheap to be true, IT IS. The end.
No more Hondas.
1968 Dodge Dart Daily Driver.
Serj22 is offline
Closed Thread
