Old 07-08-2008, 08:15 AM   #1 (permalink)
omdaspirations's Avatar
Car: 97 Honda Civic Ex
Mods: 05ex Rims, Coilovers, tokico blues, e46 projector Retrofit, Front Lip, high flow cat, Meagan Catback, and my custom JDM Autozone Intake =)... yeah!
omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?omdaspirations What did you do to deserve all this rep?
Play in Gas pedal.
Hope all is well with everyone. So i just picked up a throttle body with a TPS and have to swap out the old one. I was wondering, while i'm already messing with the throttle, is there a way that i can adjust the accelerator? There is a lot of play in the pedal before it engages and my old 97 was not like that at all. Its a 99 Ex. Thanks in advance SHO!
omdaspirations is offline
Old 07-08-2008, 03:36 PM   #2 (permalink)
Dark Wind
Car: 1994 Civic EX, 1998 Ranger
Mods: both stock
Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?Anomoly Why haven't you checked into rep rehab yet?
look at your intake manifold where the cable bolts to the manifold, with a little bit of mechanical inclination youll figure it out
ok so i dont look like a total ass here.....see where the cable comes out of its sheathing and there are 2 nuts jammed up on the bracket? loosen them and pull the cable back until it is just barely tight NOT TIGHT leave a hint of slack, then tighten the jamb nuts you should be good to go, if not i know on some models there is an adjustment at the pedal as well, not sure about yours though, also make sure you routed the cable the right way when you put it back on, that will affect it too
Anomoly is offline
Old 07-10-2008, 04:05 PM   #3 (permalink)
midnite_racer95's Avatar
Car: 1995 Honda Civic
Mods: tenzo Cold air intake, 2 1/2 inch OBX type X exhaust, 1.5 eibach dropped springs, KYB adjustable shocks, 16" low pro wheels, 205/45zr16, angel eye projector headlights, euro tails and corners, b18c swap converted to 5 speed
midnite_racer95 is a jewel in the roughmidnite_racer95 is a jewel in the roughmidnite_racer95 is a jewel in the roughmidnite_racer95 is a jewel in the rough
and to add, adjust a lil bit at a time...I tightened mine 5 thousand times before I got it right. Basicaly adjusted it to where it would run at 5,000 rpm, adjusted a lil more than it was too loose. just be careful
Never take a laxative and sleeping pill on the same night...
midnite_racer95 is offline
Old 07-10-2008, 04:09 PM   #4 (permalink)
Dark Wind
Mods: both stock
yes be careful, watch the little throttle stop screw, make sure the piece that the cable is connected to NEVER LEAVES contact with the set screw, if it does you will get the 5k idle
Anomoly is offline
Old 07-10-2008, 04:32 PM   #5 (permalink)
yeah, not that I'm saying that from experience or anything...
