Originally Posted by ltlblkcvc
you must have missed where I said on the obd2 y8 the cps(crankshaft positions sensor) is on the front of the engine at the crank and the obd1 z6 the cps is in the distributor itself. he can't just use his old dizzy without modification.
That is not correct. The distributors have all the same sensors inside them, internally they function exactly the same. The sensor on the end of the crank with OBD2 engines is the CKF (crank fluctuation sensor) it is an additional sensor for OBD2, which he will be throwing a code for unless he changes the oil pump w/sensor, timing belt gear, & lower timing cover to the Y8 ones.
I have gutted swapped back and forth OBD1 with OBD2 distributor internals, also between B-series and D-series they are compatible. First thing would be to try to install the Y8 distributor but if it doesn't fit then swap the internals from the Y8 dizzy over into the Z6 dizzy housing. If you need help I'm planning to make a write-up on it.
