Mods: B&M short shifter. KYB AGX's, Kazera StreetSport Springs, Megan Racing 4-2-1 Headers, ES bushing kit. A well maintained 300k+ car.
I work for an auto company's distrubition center so I can get parts pretty dang cheap.(about 50-75% cheaper than retail) So when I go to work on Monday I will see how much ball joints are and probably just go ahead and replace them. I think that one of the studs is beyond repair anyways. Will the ball joint on the tie rod be listed as a lower ball joint also, or is it listed as something else?
Should the outer ball joint be sold separately? On the napa online site I can only find it as the whole outer unit. I was also kind of confused because there are several different ones that it says are applicable for my vehicle. There is a regular one, one for power steering, and one for rack and pinion w/ power steering. I know that there is power steering. But is there rack and pinion?
I finally got the knuckle back on!! YES! Thanks for the help. There is another problem now.
I cannot get the brakes back on! It seems like they are clamped down too tight. They will not fit over the rotors. I tried bleeding some fluid out but it will not open up anymore. Help please! I want to be done with this!
