Old 08-07-2005, 12:58 PM   #1 (permalink)
Dark Samurai
96civic3door's Avatar
Car: 00 Corvette 'Vert M6
Mods: Bolt ons and a tune, 12.68 at 112mph in the 1/4 mile
96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy96civic3door needs rep therapy
TPS voltage
What is the TPS supposed to read cause mine is 1.1v closed and 3.8v at WOT
96civic3door is offline
Old 08-07-2005, 07:35 PM   #2 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
.48-.49v at idle and 4.5v @WOT.
You have to set the WOT before you can set the idle.
kommon_sense is offline
Old 08-07-2005, 08:27 PM   #3 (permalink)
Dark Samurai
How do I set it?
Old 08-08-2005, 07:22 AM   #4 (permalink)
Is this an original unmodified throttle body? If so, then probably time for a new tps. First off, the TPS is a potentiometer. You can google for info on how potentiometers work. You need to do the following :
- Get several feet of wire. At least 6ft to make life easy. Cut them into 6 1' pieces and strip the ends. Now twist 2 pieces of wire together. So now you have 3 2' wires with the ends stripped and a stripped spot in the middle.
- There are 3 wires/pins for the tps sensor. 2 outside wires are ground and 5v source. Middle wire is the return voltage on the tps.
- Remove the throttle body, and connect your new spliced wires to the pins on the tps sensor on the throttle body and the pins on the wiring harness.
- Now connect your multimeter to the 2 outside wires (easiest to do this at the stripped points in the middle of the wires). This will also show you which wire is ground and wich is 5v.
- Turn the ignition to on (but do not start the car).
- Verify that you have 5v going to the tps.
- Now connect the multimeter to ground and the middle wire to measure tps voltage.
- TPS sensor is held in place by 2 screws. Open the throttle rotor to WOT and keep rotating the sensor until you get the output shown on the multimeter to 4.5v.
- Tighten tps sensor down & adjust idle setting screw shown in the pic below. Adjust this until the idle reading on the tps is about 0.48-0.49v.
- Now double check that WOT & idle tps readings are correct and put it all back together.
Old 08-08-2005, 08:50 AM   #5 (permalink)
Dark Samurai
Thanks Kommon, I was told this may be what is causing my low end problem and the TB is the stock one on the D15B but I did replace the TPS while doing the swap
Old 08-08-2005, 09:47 AM   #6 (permalink)
Yep, then this is most definately the problem.
Old 09-11-2005, 05:48 PM   #7 (permalink)
Car: 1998 honda civic hatch cxi (EK1)
Mods: i have 2.5" cat back exhaust simota pod and induction kit, 17x7 ASA SPYDER DKD, underbody neon custom side skirtz
_Robert_ is an unknown quantity at this point
what does wot stand for
_Robert_ is offline
Old 09-11-2005, 05:55 PM   #8 (permalink)
Premium Member
ILIKEDINGLEBERRIES
ltlblkcvc's Avatar
Car: 99 Civic
ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?ltlblkcvc you're still here?
are you kidding? wide open throttle
ltlblkcvc is offline
Old 01-25-2008, 02:58 AM   #9 (permalink)
sinanovicha is on a distinguished road
so idle is calibrated by adjusting idle like the way when the car is on? once adjusted WOT by measuring the middle wire, car off, gas pedal down (wot), ?
http://hondaswap.com/~pills/obd1guide.html
this website also shows how to calibrate tps, he also says calibrate wot, tighten tps, and than calibrate idle, cant calibrate idle by moving tps when its tightend.. just not sure how to do it
sinanovicha is offline
Old 01-25-2008, 09:42 AM   #10 (permalink)
I'm not sure that I follow? That was all stated earlier in the thread. Were you looking for additional clarification on a part of the process?
Old 01-25-2008, 11:53 AM   #11 (permalink)
im just confused, ive read some other forums on how to do this and now im confused,
the one above said, measure the middle wire, turn TPS once is right volt, and tie it down, but if i tie that down how will i measure idle than? ovbiosly i dont twist the tps anymore, so its the normal idle that i have to adjust and measure midle wire while i do it
..i was just going to stripe a little wire on all 3 wires coming from tps and have a friend help me through this process if this helps
Old 01-25-2008, 01:39 PM   #12 (permalink)
look at the pic of the throttle body that I posted. the idle adjustment has nothing to do with rotating the tps sensor. You rotate tps to set WOT, then use the idle stop adjustment screw to set idle/closed.
Old 01-25-2008, 04:46 PM   #13 (permalink)
AyAy Sir! thats all i wanted to know, wot is calibrated by twisting the TPS and measuring the middle wire with voltmeter =) and idle is measured well ^^^^ like you said! thanks a bunch, i just like to clarify before i go deeper =) thanks!
lol one more confirm please
while im still measuring the middle wire of the TPS and adjusting the idle stop adjustment screw the volt will change?
» Site Navigation
» Home
 > FAQ
» Other Sites
