Transmission problem
I dont know if theres a transmission section here if there is let me know. I just changed the clutch and pressure plate on a civic and it still doesn't move forward. The axles are not broken.
ALTHOUGH i did forget to put fluid in after putting the tranny back on. Would low fluid give the same symtoms as a bad clutch? Or even with insufficient fluid would it still grab?
