Unstable Steering How to Fix? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 11-06-2006, 08:59 AM   #1 (permalink)
Car: 1992 Honda Civic
Mods: None
buzlink is an unknown quantity at this point
tech wrench Unstable Steering How to Fix?
I have been combating a problem for sometime, of my steering wheel being very loose and wiggly feeling. As of recently my car has become very unstable while driving from a take off as well when driving on the highway with windy conditions. When I take off the car bounces from left to right, very sporadically and can be even worse when road conditions are bumpy. To correct this I have to pay special attention to my steering and correct this before I jump into another lane. This is very frustrating as my steering wheel isn't as accurate as it use to be.
What do I need to replace/fix to get rid of this problem?
92 Civic Sedan DX
1992 Honda Civic DX Sedan
EG8 Frost White
Stock
200,000
9-21-03; 10:23
buzlink is offline
Old 11-06-2006, 10:04 AM   #2 (permalink)
nbboy7's Avatar
Car: 93 Del Sol SI
Mods: Come and find out
nbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problemnbboy7 has a Rep problem
it could be a bad rackopion becuase it cause the steering wheel to move alot with very little responce
nbboy7 is offline
Old 11-06-2006, 10:09 AM   #3 (permalink)
BurntRubber87's Avatar
BurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapyBurntRubber87 needs rep therapy
Thats sounds like a worn out tie rod end..jack up your car, so that the wheel is off the ground then grab the wheel and tire and try pull/push on it like you're tryin to turn it..if there is alot of play, you should replace the tie rod ends.
1990 Accord EX
BurntRubber87 is offline
Old 11-06-2006, 01:04 PM   #4 (permalink)
Mods: None
There is allot of play when trying to pull on the wheel back and forth.
Are there any right ups and or pictures describing how to replace tie rods?
Where is the best place to get new tie rods.
EG8 Frost White
Stock
200,000
9-21-03; 10:23
buzlink is offline
Old 11-06-2006, 02:17 PM   #5 (permalink)
90lxcivicnocat's Avatar
Car: 88 honda prelude 2.0si 4ws
Mods: its got 4 wheel steer 134ft lbs of torque, what do i need?
90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem90lxcivicnocat has a Rep problem
burntrubber is right i had a few cars like that, there should be something in the stickies on it, fix it asap before u wreck it, its just tierod ends, i hope anyways, they are easier to replace than a rack, but u tested it the right way so it must be
96 civic lx wants boost
98 mitsu gs 420a project boost whore, for sale
89 jeep cherokee
68 ford f250 for sale
87 ford mustang lx 5.0 5 speed as of 3-25-12
JDM HEAD SLUDGE BELOW
TECH
90lxcivicnocat is offline
Old 11-06-2006, 03:31 PM   #6 (permalink)
jon
jon's Avatar
Car: 2007 f150 xlt lariat
Mods: Toolbox
those are a thing where if you dont know how to replace them, leave it to a shop and have it aligned
Founding member of the Superhonda Drunken Asshole Commission
jon is offline
Old 11-06-2006, 03:54 PM   #7 (permalink)
GunMetal Member
89civic4door's Avatar
Car: 1994 integra ls
Mods: b16 pistions, b20 cams, double layer head gasket,milled head
89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life89civic4door You need a life
yep.
89civic4door is offline
Old 11-06-2006, 10:08 PM   #8 (permalink)
Mods: None
What about Rack Guide Adjustment?
P 17-5 in the Service Manual.
Could this help out, as well?
EG8 Frost White
Stock
200,000
9-21-03; 10:23
buzlink is offline
Old 11-06-2006, 10:13 PM   #9 (permalink)
let a shop do it, its no joke if u cannot control ur car, since u would have a shop fix it they would check it all out , they are going to charge u for looking at it no matter.
89 jeep cherokee
TECH
Old 11-07-2006, 09:48 AM   #10 (permalink)
nbboy7's Avatar
Car: 93 Del Sol SI
First remove this nut:
Nut loosened:
Then use a fork or tie rod puller to separate the ball joint. This should be really easy because if you're replacing it your ball joint is probably already bad. I found that hitting the threads of the joint from the bottom with a sledge hammer works very nicely
Then the tie rod end just unscrews right off. Very Easy.
Pics of old vs. new tie rod end:
nbboy7 is offline
Old 11-07-2006, 10:10 AM   #11 (permalink)
Mods: None
Thanks for the pics,
Working on the car right now.
EG8 Frost White
Stock
200,000
9-21-03; 10:23
buzlink is offline
Old 11-07-2006, 02:00 PM   #12 (permalink)
Thorgs's Avatar
Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!
92 Civic Sedan DX
well you are from Kansas so the windy conditions would probably be tornados...hence the bad steering in the windy weather
Thorgs is offline
Old 11-07-2006, 02:06 PM   #13 (permalink)
Thorgs's Avatar
is this a pretty good price for these parts?
Parts
Thorgs is offline
Old 11-07-2006, 02:07 PM   #14 (permalink)
Nut loosened:
good post, lol, urs was bent too? so how much did those cost?? im thinkn i need to replace mine sooner or later
89 jeep cherokee
TECH
Old 11-07-2006, 02:10 PM   #15 (permalink)
ok so now the important thing how do u know how far to screw the new one on???do u mark the tread before removing the old tie rod??
89 jeep cherokee
TECH
