02-15-2008, 10:52 AM
#1 (permalink)
wont start in cold weather
new here...iv searched sevrl places and have had no luck.....1998 honda civic 4banger auto....when cold temp around 30 deg. car wont start...spins over but want crank...as soon as temps outside warm up car starts and runs great...its probably a sensor but what one and where is it or they located...thanks for any help
02-15-2008, 11:04 AM
#2 (permalink)
Car: 98 Civic Ex Coupe
Not really any sensors involved in starting that would care about temperature. Makes me wonder about the battery. How old is it? How long has it had this problem? Did it have it last winter as well? Might not have enough CCA (cold-cranking amps). Just a guess.
02-15-2008, 11:17 AM
#3 (permalink)
nope ,not the battery and it does have sensors one i think is called a tw sensor and another that is in the intake air boot...there is something that controls cold starting ...i will find it eventually,i was hopeing someone had already addressed this problem to save some time...
02-15-2008, 11:43 AM
#4 (permalink)
Car: 04honda civic dx
Mods: none until i pay it off :(
maybe ur gas is frozen
02-15-2008, 01:24 PM
#5 (permalink)
i live in louisiana too ... i dont think the gas is frozen ... does your gas freeze??
02-15-2008, 01:50 PM
#6 (permalink)
no it doesnt, i was jokin lol...but where in LA u live??
02-15-2008, 01:55 PM
#7 (permalink)
walker louisiana just west of you
02-15-2008, 05:15 PM
#8 (permalink)
Car: 1996 Plymouth Breeze; 1990 CRX; 1983 Caballero Diablo (El Camino)
Mods: Rebuilt B18A1 with replacement oem rods, pistons, rings, a port and polished head, replacement valves, valve angling, dual valve springs, STR cams, Edlebrock intake manifold, custom cold air intake, Chikara header, custom-welded 3" exhaust; limited-slip differential, double plate clutch, short-throw shifter.
I'm not sure of there being any sensor that would affect the starting of vehicle due to temperature changes...But all of my vehicle are hard-to-start when it's cold out (I live in Ohio and we usually see single digits and negative number for a few months in winter)...Have you tested the amount of anti-freeze in your car (if not an anti-freeze tester is only like a dollar and be picked up anywhere)? It could also be your battery...I know that when the temperatures around here got to the point of below freezing and stayed that way for a week or so that I had to switch the oil being used in my Blazer (the owner's manual gave a chart, temperature-what type of oil should be used). You may want to look into that also. But for 30 degrees you shouldn't have to do that (I wouldn't think so anyways).
Originally Posted by hndacvcsi
you two are window licking, fucktards  .
02-15-2008, 05:23 PM
#9 (permalink)
Mods: yes, please.
hey i'm in BR welcome to SHO. no idea why your car won't start but these guys will get you sorted out i'm sure.
Originally Posted by B-rex;
02-15-2008, 05:24 PM
#10 (permalink)
Mods: yes, please.
i don't think it's even gotten down near 30 here.. maybe in january. it's 62 right now.
02-15-2008, 07:14 PM
#11 (permalink)
ill find out and when i do i will post it so people will know ----an know its not the battery/coolant/tune up/oil or the brand tires i use...the car turns over fine and when it gets warm enough outside it starts up perfect and runs perfect...thanks
02-15-2008, 11:36 PM
#12 (permalink)
Lucky, lucky, lucky....just this past week we had a spurt of cold weather, with wind-chill factor it was -30.
02-16-2008, 02:34 AM
#13 (permalink)
Mods: yes, please.
yeah i wouldn't call it lucky in august though..
02-16-2008, 08:46 AM
#14 (permalink)
Car: 2000 Civic EX
Mods: Gearspeed LSD tranny, Clutchmaster Stage3 Fidanza, solid mounts, header, full exhaust, high-flow cat, intake, Drag DR-11s, cross-drilled and slotted rotors, SPC suspension pieces, strut bar, 2" drop, built head, Skunk2 intake manifold, AEM fuel rail and FPR, Hondata S200
I'm suffering and its 48 degrees here. Granted I work outside...
Mazda/Hyundai GOLD MASTER Tech in Tucson
Got me the SLWCVC
02-16-2008, 09:14 AM
#15 (permalink)
Car: 00' Dx Hatch
