Old 01-12-2004, 06:46 AM   #1 (permalink)
guest is an unknown quantity at this point
yet another idle problem, but I have tried alot
I have a 89 dx. The idle is horrible. It starts high (1500-2000) lowers a bit then goes up and down. As the motor gets to op. temp it get worse. The throttle body is clean, I cleand the eacv, Adjusted throttle linkage, etc... I'm going to clean the pcv and get new homemade grounds for battery and valve cover, well that help. Also I checked the cap and rotor and they don't look good, so i'm thinking it's that and another thing when you check the coil do you test it with a voltmeter with the negitive cable connected and/or with the ignition in the on position (not started)? o yeah i'm thinking of retarding the timing and seeing what happens?
guest is offline
Old 01-12-2004, 02:36 PM   #2 (permalink)
BlackDx is an unknown quantity at this point
hanes maunal say to check it with the ignition switch off. and it says to check with ohmmeter. Don't know if that is what you got or not...but whatever.
BlackDx is offline
Old 01-12-2004, 07:29 PM   #3 (permalink)
ExViTermini's Avatar
Car: 96 Honda Civic
Mods: H22, soon to be boosted.
ExViTermini is a jewel in the roughExViTermini is a jewel in the roughExViTermini is a jewel in the rough
the idle is supposed to start out high when it is cold or very first started up...when you say eacv I think you mean IACV, I think it may be a good idea to check that the map sensor is ok and that there are no vacuum leaks too.
Originally Posted by Cost
ExViTermini is offline
Old 01-12-2004, 10:25 PM   #4 (permalink)
Car: 94 civic ex
Mods: K&N filter, tokico illuminas/RS*R springs (1.5"drop), PIAA's all around, Neuspeed Strut Tower Bar, crazy system!(rattles the car with only one 10!), Skunk2 Dual Bend Short Shifter(WELL WORTH THE MONEY!)...turbo soon...muhahahaha PEACE!
crshovrd41 is on a distinguished road
another guy on the board had a similar problem and he said he had a blown head gasket and lost all compression in cylinder 3 or something...but i also have the same problem with the idle...but i have a chipped ECU and it just started recently..check your ecu to see if it has thrown any codes...peace..
brandon
Killing is wrong...there should be a new word for killing...like bad wrong...or...badong
crshovrd41 is offline
Old 01-12-2004, 11:57 PM   #5 (permalink)
Car: civic lx 95
Hybridalien is an unknown quantity at this point
try to look for a vacuum leak.
Hybridalien is offline
Old 01-14-2004, 03:41 PM   #6 (permalink)
I'm not throwing any codes, my compression is like about 195-215 or so across the block, with if i'm correct is a little high meaning carbon deposits? I was thinking of maybe using sea foam or automatic tranny fluid to clean that sometime, but i'm guessing compression is ok? I'll check the map and for vacuum leaks.
guest is offline
Old 01-14-2004, 06:23 PM   #7 (permalink)
brandon
i just blew my head gasket on my D16Y8 and if the idle is the only thing that is wrong with car then it shouldn't be that. The car would run fine and idle weird. With blown head gasket (in my case atleast) the car ran like ass and would idle about normal pace for few seconds then jump really low.
First time blow'n head gasket so don't know if that is how it always is but I wouldn't assume its that serious.
BlackDx is offline
Old 01-14-2004, 06:45 PM   #8 (permalink)
It runs good, but the idle is extremely bad. I'm using a throttle body gasket that's bored bigger than the dx throttle body, would that cause a bad idle?
guest is offline
Old 01-14-2004, 06:48 PM   #9 (permalink)
Car: 94 ETC, 1988 RX7 10thAE, 1992 DA integra
Mods: Caddy is for sale, Rx7 is for sale to make way for the DA
capn will become famous soon enough
i would clean your IACV and clean the screens out cause most idle problems i see the IACV is usually the cause
I am not young enough to know everything yet.
capn is offline
Old 01-14-2004, 06:58 PM   #10 (permalink)
I cleaned the ecav. I took it off and sprayed carb cleaner in it, is there a screen in obd-0 ecav cause mine didn't have one? I believe it's ecav on obd-0.
guest is offline
Old 01-14-2004, 07:36 PM   #11 (permalink)
bobbo is an unknown quantity at this point
I have an IACV for sale if you are looking for a replacement. Let me know
bobbo is offline
Old 01-26-2004, 10:23 PM   #12 (permalink)
I put in a used ecav from a junkyard( I cleaned it) with, who know how many miles on it. I also put stp fuel injector cleaner in it and it still idle's horrible. when you put the butterfly valve in, it has to be turned twice to get the tps to face the engine. I had to move the tps to seat right. I think it might have to turn the valve back a half turn? I'm thinking of buying a bunch of vaccum hose and replace all the hose's? I need help bad.
guest is offline
Old 01-27-2004, 10:49 AM   #13 (permalink)
Car: Dropped, swapped Civic with some other shit
Mods: ..........
PointBlank is an unknown quantity at this point
First thing you ever check for when a car idles funny like that is vaccuum hoses. That's most likely what it is, seeing as you aren't throwing any codes.
Check the voltage on your TPS.
Check vaccuum hoses for leaks
Air could be bypassing the blade of your TB, too.
PointBlank is offline
Old 01-27-2004, 12:47 PM   #14 (permalink)
i'll check the vaccum hose's. when checking the tps voltage, do you test the actual tps prongs or the connector on the wiring harness?
guest is offline
Old 01-27-2004, 01:04 PM   #15 (permalink)
Mods: ..........
Use a voltometer on the TPS itsself.
