Yep for sure you can do it but you will rub at stock height so lowered you will definately rub. The solution would be 5 to 10mm spacers.
I ran 225/45/15 Hoosiers on 15x7" Volk Te 37's all around in (SM) last season on my stock suspension and I rubbed in the front on the wheel well plastic liner near the timing belt hole, and on the front of the rear LCA's.
I will be running 225/45/15's Ecsta Supras this season Still on the stock suspension but, the Khumo is not as wide as the Hoosier so they will not rub or nearly as much.
But, if you are lowered then you will guaranteed rub.
Good luck,
A.
