Old 06-16-2005, 10:21 PM   #1 (permalink)
Brad98_teg's Avatar
Car: 1998 Integra LS
Mods: BoOsT
Brad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problemBrad98_teg has a Rep problem
3rd gear grindage
Ok, so for the last couple of days when i take 2nd gear to the higher RPMs and shift to 3rd it makes a quick sound of a grind. During normal driving or if I do take 2nd into the high RPMs and before i shift let it fall to about 4k then there is no grind. So Im trying to think of what could be causing this, my rear motor mounts?syncro's?tranny fluid needing replacment? :bh anyone have an idea of what this could be?
thanks.
1998 Integra LS
13.9 @103 on street tires
Brad98_teg is offline
Old 06-16-2005, 10:31 PM   #2 (permalink)
TypeG is a name known to allTypeG is a name known to allTypeG is a name known to allTypeG is a name known to allTypeG is a name known to allTypeG is a name known to all
it could be a few things. i would check the tans fluid level and add if needed. it sounds like bad syncro's. or maybe even a worn clutch, clutch master cylinder, or slave. have you added anything like a short throw shifter, i've seen peps put them on backwards. hope this helps. later
TypeG is offline
Old 06-16-2005, 10:51 PM   #3 (permalink)
Brad98_teg's Avatar
Mods: BoOsT
Its all stock and the tranny fluid was replaced at 65,000 and i just hit 93,000
I'm pretty sure its not my clutch...but i will try to get it all checked out soon.
1998 Integra LS
Old 06-16-2005, 11:50 PM   #4 (permalink)
Car: 95 integra
Mods: under construction
lshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whorelshybrid195 is a rep whore
that sound like the syncros is bad
lshybrid195 is offline
Old 06-17-2005, 12:23 PM   #5 (permalink)
Car: 89 CRX Si
teamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these partsteamhonda_69 is infamous around these parts
oh yes the old third gear grind well, I had the same prob. only much worse mine use to grind at like 2-3K heres what I did....
EDIT: get the friction-modified one
The answer to all grindage
also how is hp/l going again how is that going to help out on anything? it doesn't make you faster doesn't make you slower doesn't make you cooler it's just another way to spank the monkey-rx7speed -
Dirt track DA #No2 Back In Black
My car domain page
teamhonda_69 is offline
Old 06-22-2005, 05:41 AM   #6 (permalink)
As good as synchrmesh is, it won't save the grinding if the synchro's are bad. And it sure does sound like a synchro problem (high rpm grinding, but goes away at low rpm's).
However, I do recommend doing a simple tranny fluid change. At about 30k, I would definately recommend changing the fluid out ASAP.
female four is offline
Old 06-22-2005, 09:41 AM   #7 (permalink)
Car: 89 CRX Si
I see what your saying but, what could it hurt? im sure my third gear synchro is down to nothing but you couldnt tell by driving it even at high rpms
My car domain page
