93 Teg ABS Reservior & Transmission Questions
I have a 93 Acura Integra, I seem to be losing fluid out of the ABS reservior and have no idea where it is leaking from. We thought maybe the cap, any possibility? Is there any way it could leak from the bottom of the reservior or ABS block? All lines seem to be tight with no signs of leaking or wetness. Also, there is an intermittent noise coming from the transmission side of the engine. It almost sounds like a bearing going bad, but were wondering if it may be the throw out bearing. It only happens once in a while, only lasts for 30 seconds to a minute, an depressing the clutch has no effect on the noise, it just stops on it's own.
