Old 06-28-2008, 09:50 AM   #1 (permalink)
Joewill2848's Avatar
Car: 89 crx si
Mods: 17" wheels cat back exaust black halo headlights black corner lights clear marker lights blck rcing seats 4 point harnesses spoon sports steering wheel blacked out windows strut tower bar skunk2 shift nob complete energy suspension bushing kit energy suspension mtr mnts white face gauges body kit fresh red paint battery discnect swtch lambodoors
Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848 Joewill2848
95 b18 ls with gsr tranny
ok im putting a 95 ls motor and gsr tranny into my 89 crx it will be accompanied by hasport mount with hydro conversion, act clutch, rywire harness and ecu. when done right im wondering what number i should be putting down in the 8th mile any help would be appreciated
on my 14th car and i doubt the madness stops here
Joewill2848 is offline
Old 06-28-2008, 01:14 PM   #2 (permalink)
holloway's Avatar
Car: 96 hatch
holloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problemholloway has a Rep problem
If you can drive high 8's to low 9's
holloway is offline
Old 06-28-2008, 01:26 PM   #3 (permalink)
clayton's Avatar
Car: '01 F350 SRW
Mods: it's not stock.
bench racing is pointless. build it & find out.
Originally Posted by B-rex;
clayton is offline
Old 06-28-2008, 02:13 PM   #4 (permalink)
Car: 89 crx si
wow thank u for nothing flush
Old 06-28-2008, 02:19 PM   #5 (permalink)
clayton's Avatar
Car: '01 F350 SRW
dude what are you trying to accomplish by having some stranger on a forum speculate what kind of times you might run if you drive like them or whoever they knew and build the exact same car? you just want to say, "my car's going to do..." or what?
clayton is offline
Old 06-28-2008, 02:30 PM   #6 (permalink)
ProjectDC4's Avatar
Car: 1997 Acura Integra RS
Mods: Broken Necks
ProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a lifeProjectDC4 You need a life
8th of a mile? how far is that, 3rd gear only?
compare it! 145hp into a 2000lbs car.
13.8lbs-1hp
7/10 power to weight ratio. thats good in my books
ProjectDC4 is offline
Old 06-28-2008, 02:37 PM   #7 (permalink)
Car: 89 crx si
look im just trying to get an idea if i do the swap right with everything running good what i may expect there is not an initial answer just looking for opinions if you are going to be rude i dont want them if you want to share knowledge and information i am more and glad to be here thanks dc4
Old 06-29-2008, 09:38 AM   #8 (permalink)
clayton's Avatar
Car: '01 F350 SRW
thx for the negative rep.
sry you can't handle it, but the truth is, there are so many variables, (like i said before) it's pointless.
clayton is offline
Old 06-29-2008, 11:08 AM   #9 (permalink)
Car: 89 crx si
hey like i said keep it
Old 06-29-2008, 01:42 PM   #10 (permalink)
CapnToll's Avatar
Car: 1996 Integra SE
Mods: See the sig.
The reason behind this being kind of a pointless question lies in the following variables:
Engine Compression (engine making full OEM compression? Is it a bit tired? Has it been maintained?)
Tires (New, old, hard, sticky, slicks)
Suspension (new, old, driveshaft geometry screwed up because of the swap)
Driver (good, bad, decent, first time, veteran, used to clutch)
Track Temperature
Track Altitude
Traction Compound on the track
Exact Weights
Aftermarket Mods
With all these variables, you could have what you think are two exactly the same setups running times 3-4 seconds different from each other.
The better thing to do, is to REACT to and Discuss the time you ran at the track knowing your setup.
1996 Acura Integra SE
Motor: BC0022 Cams, Crower V/T, AEM Cam Gears, Comptech Icebox, Skunk2 I/M w/ Hondata gasket, DC-S 4-2-1 Header, 2.07" Brullen Cat-Back, B&M FPR, FAL Rad/AC Fans.
Tuning: UBERDATA, FJO Racing Wideband AFR System/Gauge
Security: Computer chip ignition Immobilizer, Intrusion alarm, Glass break alarm, and of course... THE BAR!!
Old Dyno: 175whp @ 7500 RPM / 135wtq @ 7000 RPM........ERTW
2001 Toyota Highlander V6 4WD - Winter Car - 220bhp / 222tq Bone Stock Baby!
CapnToll is online now
Old 06-29-2008, 08:53 PM   #11 (permalink)
clayton's Avatar
Car: '01 F350 SRW
whatever dude, i know what my cars run in the 1/4 mile, and my rep is still green.
clayton is offline
Old 07-03-2008, 04:03 PM   #12 (permalink)
Car: 89 crx si
preciate it capntoll and as for clayton it looks as if u have a diesel what are u on here for anyways and if u do have a honda great but stay off my threads please
Old 07-04-2008, 02:37 AM   #13 (permalink)
clayton's Avatar
Car: '01 F350 SRW
um, no. not your thread. our thread. i have 2 hondas, thx for asking. i'm all for you building a great car, but i can't fathom what you'd want us to pull a number out our asses for. gimme a good reason & i'll leave it be.
i love how you tell capn you 'preciate it and negative rep me for saying very similar things.. sorry i didn't break down why bench racing is pointless so thoroughly for you.
clayton is offline
Old 07-04-2008, 09:54 AM   #14 (permalink)
Car: 89 crx si
the reason i appreciate what he said he put facts behind it not some bullshit to sound like an asshole
Old 07-04-2008, 10:50 AM   #15 (permalink)
MQTGSR's Avatar
Mods: mAd JDM ShIT Yo!!
