Old 06-09-2008, 09:18 AM   #16 (permalink)
Shafto's Avatar
Car: 1997 Acura Integra
Mods: Nada
Shafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peonsShafto Hello down there miniscule peons
Originally Posted by flyracerx View Post
did you try cleaning injectors? or perhaps replacing them?
that is exactly what I was going to say. I think you have dirty injectors. When your engine is cold, fuel has a harder time atomizing. At the same time if your injectors are concentrating the spray, this fuel has a very tough time atomizing. which can lead to hard starting. Once the engine is hot, fuel will more redily atomize exanding into the heat. But then again. I would think that it would still start. Cause I would doubt that all 4 injectors are that dirty. Does sound fuel related though. Have you ever pulled a plug and checked your spark?
-I slightly pressed the throttle dipping my toes into the deep ocean of power this engine makes
Shafto is offline
Old 06-09-2008, 12:23 PM   #17 (permalink)
AdamJ is on a distinguished road
It starts easiest when the engine is cold. The fuel pump doesn't whine, the car doesn't idle rough, and there's never any kind of loss of power that would attribute a failing fuel pump. I believe my pump and injectors are fine. If the new fuel pressure regulator doesn't help the situation then I'll probably replace the starter, followed by the fuel pump.
AdamJ is offline
Old 06-09-2008, 08:26 PM   #18 (permalink)
STLAcura's Avatar
STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura STLAcura
I still say the ICM..maybe an intermittent problem in the wiring or of some sort.
STLAcura is offline
Old 06-10-2008, 02:04 AM   #19 (permalink)
Sanjay228's Avatar
Car: 2000 Acura Integra Ls
Mods: Don't have a job!
Sanjay228 is on a distinguished road
wow..
most horrible kitty death ev4r..
Yeaaa...
Apparently cats like to sleep btwn belts
2000 Integra LS Vtec
Cold air intake
thats about all
Sanjay228 is offline
Old 06-10-2008, 08:37 AM   #20 (permalink)
Shafto's Avatar
Mods: Nada
...mhmm. maybe there is some kind of check valve not really keeping the system pressureized. but that still doesnt make sence cause it starts right away when it is cold? It almost sounds like vapour lock but I doubt that too. I dont think the fuel lines are getting hot enough to turn your fuel into vapour. Could be but no. I dont know. next time I would try loosning the fuel in line and seeing what kind of pressure it gives you. It should be lots. Keep me updated on this, I am curious.
Shafto is offline
Old 06-12-2008, 07:50 PM   #21 (permalink)
I ended up taking the car to a local Acura dealership because I needed an oil change. After they changed my oil, the car wouldn't start (as usual) - they said they weren't getting any spark and blamed the ICM. Of course, they wanted nearly $300 to swap it out. I bought a new ICM at AutoZone and installed it this afternoon. I drove the car around for 10 minutes to get the temperature up then parked it in the garage. I tried to start it exactly an hour later and it had the same no-start symptoms
What the **** is the problem! My coil measured fine but maybe it's faulty?
AdamJ is offline
Old 06-12-2008, 08:51 PM   #22 (permalink)
STLAcura's Avatar
Damn...seems like you've tried everything...it's time for the nuclear option. Just start throwing parts on it and see if it fixes it.
STLAcura is offline
Old 06-12-2008, 11:20 PM   #23 (permalink)
Shafto's Avatar
Mods: Nada
check your fuel pressure after cranking it over a couple of times. Loosen it slowly as if it has pressure, it will come out fast. At least then you will know that you have fuel pressure at the fuel rail.
Shafto is offline
Old 06-13-2008, 09:21 AM   #24 (permalink)
What about the ECU? If I can get one under $50 I'll try swapping it out.
AdamJ is offline
Old 07-05-2008, 01:16 PM   #25 (permalink)
Hopefully this helps someone in the future..
I replaced the Engine Coolant Temperature (ECT) Sensor and my problems are solved. I believe my old one thought the car was cold when it was actually warm, causing the ECU to flood the engine with gasoline resulting in difficulties starting.
AdamJ is offline
Old 07-08-2008, 12:15 AM   #26 (permalink)
STLAcura's Avatar
Hmm, oh wow, would have never guessed it but a great lesson, nonetheless.
STLAcura is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
