ok...ive got a 98 GSR and my ABS light is on. checked the code, and its 12- FR Wheel Sensor electrical noise/intermittent interuption. anyone know what that means???
my ABS light would come on and stay on...i took it to a speed shop and they told me that it was my right front ABS sensor. they said that i would just have to buy a brand new one for like $300.
how did you pull your ABS code?? i need to learn how so that i can REALLY find out what's up w/my car.
thats probably what it is in jamee's case there is a lot of steps you can do that are in a Helms reading stuff out and such to make sure tahts what it is. Have you tried to erase the code? I assume if you know how to pull the code you know how to erase but then again you were talking about reseting the ECU.
To pull the code you jumper out the same wire that you do for the CEL(under the passengerside dash). Then turn the ignition to on without the brake pedal pressed. (pressing the pedal is used in erasing the code).
