Old 12-29-2002, 10:40 PM   #1 (permalink)
Car: 95 teg ls
Mods: i/e
optoomistic is a name known to alloptoomistic is a name known to alloptoomistic is a name known to alloptoomistic is a name known to alloptoomistic is a name known to alloptoomistic is a name known to all
Accord V6 calipers
do these calipers bolt right up to the integra brackets
and do itr spec rotors have 5 lug how is this problem solved
ive herd of this being done b4
and i was interested in doing it on my 95 ls
ps will 99-00 civic si brake lines fit mt teg
optoomistic is offline
Old 12-30-2002, 04:43 PM   #2 (permalink)
Car: 95 teg ls
Mods: i/e
bump
Old 12-30-2002, 05:06 PM   #3 (permalink)
Accelerazn's Avatar
Car: 02 s2k SebringS
Accelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriendAccelerazn Needs a boyfriend/girlfriend
yes they do, but you have to shave off about 2 mm of the bracket in order for the calipers to clear to rotors. I think a lot of people have done this to their cars. In fact, fastbrakes sells a kit for this as well. Oh yah also the v6 calipers are similiar to the itr calipers, as well as the accord wagon caliper and vtec prelude calipers.
heres a link that should start you off.
http://hybrid2.honda-perf.org/tech/bigbrakes.html
imma bout to do this to my car too. I got the calipers at thepartstrader.com they sell some good shit there sometimes. as for the rotors, just get some at fastbrakes.com. good luck
1993 Civic Si Hatch (so far) - neuspeed race/bilstein hd, 15" OZ ultraleggeras, DC2 ITR steering wheel (non-srs), RSX 5spd SK, Spoon front/rear strut bar.
2002 S2000 - Zeal Function XS coilovers, T1R 70R w/ GTm CF Single Exhaust Cap, Enkei RPF1s, ASM FRP Rear Trunk Spoiler, Personal Neo Grinta Steering Wheel w/ Works Bell rapfixII quickrelease, Spoon X-brace, Spoon Strutbar and lower tiebar (BLING!), ARC Ti Shift Knob, Rick's clearcorners, Clear sidemarkers. Upcoming: J's SPL header, pjdm ram intake.
Accelerazn is offline
Old 12-30-2002, 07:04 PM   #4 (permalink)
Car: 95 teg ls
Mods: i/e
balance
will braking balance be upset by just replacing the front rotors.
and calipers
of my integra with accord calipers and itr spec rotors redrilled to 4x100
dan
Old 12-31-2002, 02:08 AM   #5 (permalink)
Accelerazn's Avatar
i think you should have the prelude vtec rotors redrilled to fit your car. The 5 lug pattern of the itr will be a problem since ur car is the 4 lug pattern. The prelude rotor is basically the same size as an itr rotor after all.
and no your brake balance wont be changed since most of the braking is done up front. But people tend to upgrade the rear rotor as well to a larger one (itr spec) just for the heck of it.
Old 12-31-2002, 03:42 AM   #6 (permalink)
BlackLoTuS is an unknown quantity at this point
Talking I have done this mod...
Very big improvement on the track.
I have done this a little over a year ago and my bro just put the ITR calipers on his 94 civic hb. He had to change over to 3g teg/5g Civic EX steering knuckles and we also upgraded the mc and booster assembly to 1".
You won't have to worry about any of these except modifying the calipers. I took them to a machine shop and had them grind the mounting points down to .480" (total thickness) and its perfect. If your not sure about what to do on the calipers just buy them from fastbrakes.com. For the rotors you can get them from fastbrakes or my recomendation is to get them from raceconcepts.net. Woody hooked up my brother with a set of prelude VTEC brembo rotors (4x114) slotted, redrilled to 4x100 and zinc washed for @$130. They're local to me in OC but they ship as well.
My first set of the bigger rotors were from fastbrakes and they were slotted. I was pretty dissapointed when I recieved them because the slotting looked like 2 parallel lines crossing the edges of the disc if you can imagine that. I know its not really about the looks but they looked stupid and weren't all that cheap. After seeing my brothers rotors and the quality on them (real radial slotting!) I am definitely getting my replacement rotors from raceconcepts.net.
It must be an LS since someone took the badge...
BlackLoTuS is offline
Old 12-31-2002, 04:11 AM   #7 (permalink)
Accelerazn's Avatar
hey, did the slotting look like the rotors in this pic?
http://www.ipsracing.com/images/product_spoon_rotor.jpg
those are spoon rotors btw.
Old 01-01-2003, 01:08 AM   #8 (permalink)
Car: 95 teg ls
Mods: i/e
anybody know about those brake lines
from the civic si
will they fit on an integra
Old 01-03-2003, 05:54 PM   #9 (permalink)
Yes they looked kinda like that except it looks like someone ran a saw all the way across the entire width of the rotors instead of stopping at the hub. They warped in less time than my old smaller stock rotors and I raced about the same amount on both.
Unlike most people, I'm not one who worships the overpriced, overhyped products Spoon or Mugen put out or the products that imitate them. We haven't put that much time on these new rims but from what I can tell, the quality of the new rotors from raceconcepts.net is top notch.
edit: I guess the spoon rotors aren't really that overpriced so I take back that part...
Old 01-04-2003, 05:21 AM   #10 (permalink)
Lam
Car: works
Lam is an unknown quantity at this point
or another choice
the earlier legend GS come with two pistons...fit straight with maybe some shavings (ITR)
ask you acura dealer
Lam is offline
