Old 04-24-2005, 06:59 PM   #1 (permalink)
Car: 91 integra
Mods: everything
sebastian1023 is an unknown quantity at this point
advice, quick question
I just got a new ecu (computer at the foot of the front passenger). When I installed it, the red light blinks 13, and the check engine light turns on. What does that mean and how do I fix it?
sebastian1023 is offline
Old 04-25-2005, 12:32 AM   #2 (permalink)
acuradriva's Avatar
Car: 98 GS-R
From the stickies
ECU codes:
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
acuradriva is offline
Old 05-07-2005, 06:29 PM   #3 (permalink)
Car: 95 teg
Mods: turbod 2.0 ls-vtec
187_teg is a splendid one to behold187_teg is a splendid one to behold187_teg is a splendid one to behold187_teg is a splendid one to behold187_teg is a splendid one to behold187_teg is a splendid one to behold187_teg is a splendid one to behold
kind
what kind of ecu is it if its a p28 than u could be throwing a vtec selenoid code be check the code than u will know
187_teg is offline
