Old 02-14-2002, 05:24 PM   #1 (permalink)
BamaGSR is an unknown quantity at this point
AEM CAI=blown engine?
Hope I'm not about to become a horror story.....
A week or so ago I noticed that my GSR was missing when it idled, rest of the time it ran fine, but when I came to a stoplight it would start missing. The car had 86K miles on it, so I figured I'd take it to my 'local' Acura dealer(70 miles away), and have them check it out and get the 90K service done. Well a coupla days later suddenly the Malfunction lamp comes on, ok now I definitely call and set up an appt for the next day. When I get there they tell me I need to get the timing belt changed(I had always heard change it at 90K, so I agreed), that was over $500. They he says the 90K service was over $400, so I say forget that. Then they look at the car and tell me that the compression on the #2 cyclinder is about 25 lbs less than the other 3, which are normal. And....here's the kicker.....he said they found muddy water in my CAI. Of course he thinks I sucked some water in the engine, however the car is NOT smoking, which suggests to me that it's not the rings or a damaged cylinder. Anyway they are going to adjust the valves tomorrow(another $300), and see if that fixes it.
Any ideas as to what it could be?
BamaGSR is offline
Old 02-14-2002, 06:07 PM   #2 (permalink)
G2Integrity is an unknown quantity at this point
Oy vey, the whole bypass valve thing again. Well I'm bored, so I'll do it again. My opinion is that the bypass valve is unnecessary. To me it's like wearing a helmet when you walk around, YES the helmet works, but you're not gonna fall. Just pay attention when you drive and you should be fine. Also, the bypass valve robs a good amount of horsepower.
Oh, and about water being in your CAI, don't worry about that. Water in the filter is harmless, the intake will still suck up the air since it's lighter. You're fine.
1990 Acura Integra GS :
In the Integra and Civic switchin' four lanes, with the pedal down, peeling out, racing ain't a thang.
G2Integrity is offline
Old 02-14-2002, 06:23 PM   #3 (permalink)
cdoome2 is an unknown quantity at this point
wow adjust the valves for 300, thats some valve adjustment, id do it myself if i were you, its not hard, and will take less than an hour, i dunno what dealership you go to, but the guys at my dealership said they would do it for $50, and i wouldnt even pay that because its so simple to do.
cdoome2 is offline
Old 02-14-2002, 06:26 PM   #4 (permalink)
Skunk2TEG is an unknown quantity at this point
300 dollars for a valve adjustment? are they out of their fucking minds??? i get mine done for 60 bucks at a local import shop and even at a dealer it about 90 bucks at most....and i have had muddy droplets inside my intake before but they were dry...its ok to get a little bit of water in...it will burn off anyway..i think it only takes either a teaspoon or tablespoon to hydrolock an engine though.
Some go fast stuff
Skunk2TEG is offline
Old 02-14-2002, 06:27 PM   #5 (permalink)
also why dont you check your plugs, check your ignition timing as well.
cdoome2 is offline
Old 02-14-2002, 06:28 PM   #6 (permalink)
opps and dont forget to reset that ecu after, sorry for all the posts.
cdoome2 is offline
Old 02-14-2002, 10:45 PM   #7 (permalink)
I forgot to mention that they replaced the plugs when i took it in tues. Since then it STILL runs rough at idle, but not as bad, i'm sure that's cause the plugs are new. I've decided to cancel the appt for tomorrow and try to call around here and see if anyone in this area can do the valve adjustment for cheaper. Only problem this is rural Alabama we are talking about, mention you have an Acura that needs work and they panic.
But even the guy at the Acura dealer told me that he didnt know if the valve adjustment would fix the problem, just that they would have to try that and see. The fact that its not smoking is what's confusing me, I know I know next to nothing about cars but that suggests to me that it's NOT a matter of worn rings or cylinder damage. Does that sound right? If so does that suggest that adjusting the valves might fix it or are we shooting in the dark here? Remember he said the compression on one cylinder was low 25 lbs, could adjusting the valves fix that?
BamaGSR is offline
Old 02-15-2002, 06:56 AM   #8 (permalink)
BamaGSR is offline
Old 02-15-2002, 07:02 AM   #9 (permalink)
One more thing: I have the AEM CAI and a DC Sports ceramic header on my GSR, would it help to advance the timing to 18 degrees? It's still stock right now, would this help the rough idle?
BamaGSR is offline
Old 02-15-2002, 07:35 AM   #10 (permalink)
PAC-MAN's Avatar
PAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to doPAC-MAN Rep God/Goddess with nothing better to do
hhhhhhmmm 3 bills for a vavle adjustment! Sounds like someone trying to fuck u over! That's straight BS, like everyone else said, i've paid 60 the most and once 20 just to make sure i didn't need a valve adjustment. And the prices I'm mentioning where for my 94 GS-R
1995 EJ EX|D16Z6|T3/T04B .48a/r|15.2 psi|Scat Rods|SRP Slugs 9.1:1|Drag Turbo Manifold|Tial 38mm WG|HKS BOV|3" Open DP|uberdata P28|Precision 30" FMIC|ACT S/S Clutch|GE Block gaurd|Greddy Turbo Timer|Other Whips: 1994 Integra LS 1990 Accord Coupe H22A powered
12 sec full interior coupe!
G-Spot Ninja #1
PAC-MAN is offline
Old 02-15-2002, 11:14 AM   #11 (permalink)
you can advance the timing, id suggest 93 octane gas though.
cdoome2 is offline
Old 02-16-2002, 09:20 AM   #12 (permalink)
Car: NICU Clinical Pharmacist
Tuan is an unknown quantity at this point
sorry to hear about your engine...hope you fix it.
BTW how do you know that the muddy water (great pun..since you are indeed muddying the waters and that hydrolock would have grenaded the engine if i was real) is not coolant?
from "the Matrix": You take the blue pill. The story ends. You wake up in your bed and believe whatever you want to. You take the red pill. You stay in Wonderland and I show you how deep the rabbit hole goes. Remember all I'm offering is the truth. Nothing more." Morpheus.
Tuan is offline
Old 02-17-2002, 02:09 AM   #13 (permalink)
Did you change your plug wires ?? If you haven't, change them and see what happens. They are on Crack 300 bills for a valve adjustment !! But then again from the sounds of it they can charge whatever they want cuz they monopolized the market in your area.
Dr Drew is offline
