Damn my 94 ls doesnt go into gear when i first turn my car on or when it gets cold...... what could be wrong?
"And maybe I'll see you at a movie sneak preview
You'll show up and walk by on the arm of that guy
And I'll smile and you'll wave we'll pretend it's okay
The charade it won't last when he's gone I won't come back"
"Those who live without risk, risk not living at all."
Originally posted by 1200mk Damn my 94 ls doesnt go into gear when i first turn my car on or when it gets cold...... what could be wrong?
Have you ever Neutral Dropped It??? This can cause the tranny to mess up bad....or it could just be that you are low on tranny fluid or like CRAPPY SOL says "it needs changing"
Originally posted by 91CivicSiR Have you ever Neutral Dropped It??? This can cause the tranny to mess up bad....or it could just be that you are low on tranny fluid or like CRAPPY SOL says "it needs changing"
ive neutral dropped before...... like a year ago. Probably less than 10 times total ever. And if i change my tranny fluid do i need a new filter or just change the fluid? and is the honda oem shit better than lets say valoline tranny fluid? thanks
Mods: Mostly Show Now , The PSsSSSttt is coming this summer
when i had my auto teg back in the day i had the same problem , it came to the point where it wouldnt shift to any gear , the proble was my shift linkage was bad and had to be changed,P.S if you dont know thats the cable that moves up and down when u take the car out of P-R-N-D-2-1 it was an older ls tho so they might work different
i believe a neutral drop is when you put the auto tranny in neutral, rev and put it back into drive while revving/while revs are up.... some1 correct me if im wrong
a better way is to depress both the brake and the gas at the same time, to get the revs up, and then take your foot off the brake. (This is also BAD for your trannie, but not as bad as a neutral drop) If you rev to high, you hit your torque converter's stall speed.
"Racing is a matter of spirit not strength."
On some models the AC controls are located on the door panels. Temperature is selected by how far you rotate the crank and the fan is operated by the long skinny pedal to the far right. The further you depress this pedal, the higher the air flow.
