what exactly do u plan on doing to ur gsr? is it just a straight head swap? r u going to replace the pistons? if ur just swapping the gsr head for the b16 head for better flow, ur going to be better off with ur gsr head and skunk2 manifold. check out this flow comparison:
also, keep in mind that if u plan on just sticking with ur stock pistons, swapping a b16 or ITR head on ur gsr block will lower ur compression since the b16 and ITR combustion chambers are larger when compared to tighter combustion specs to that of the gsr's.
hth.
