Ok this my question, but first my setup b20b block with eagle rods, JE pistons(com:10:5:1) Block guard. jdm 2nd gen b16 head with crower double valve springs, retainers, valves. Jdm Type r Cams, aem cam gears, stage 1 port and polish 5 angle valve job. Jackson Racing Supercharger on 9 lb's. Now my question is , Me and my good friend put the block together. our selfs. the block had 50k miles on it. So we took out rod journals and lubed it up good but put them back, The crank wasnt blue printed or balanced, cause it was never pulled out of the block. so i just left it like that i then mated the head and block with arp head bolts. Now Its time to drop it and im afraid cause everywhere i read all about blue printing and balancing crank. Am i running a Risk, or is it a sure thing that my block will blow. Any Inputs will be greatly appriciated. Also what kind of whp would you consider this setup having? With 390 cc injectors, walbro fuel pump, aem fuel rail, fuel pressure regulator and skunk 2 chipped p28 for turbo set up and thrust piggy back. Type r tranny.? Thanks. Sorry for the story i just want to be on the safe side.
