Old 06-20-2002, 09:15 AM   #1 (permalink)
Car: 2004 WRX STi (For Sale)
Gsr95Vtec is an unknown quantity at this point
Unhappy Is it a bad head gasket?
Hy, I had posted earlier that my car was burning lots of oil and I said that I thought it was my piston wrings.. But yesterday I was checking the raidiater fluid and there was oil in my reservoir:eek:. Could that mean I have a bad head gasket and oil is slipping threw the gasket into the raidiater fliud passage, and could that be why my car does not always blow smoke from the rear it happens on an off? PLEASE HELP!!!
1995 Acura Integra GS-R (sold) it will be missed.
2004 Subaru Impreza WRX STi (For Sale)
Gsr95Vtec is offline
Old 06-20-2002, 09:57 AM   #2 (permalink)
Car: 1987 RX-7 Turbo II (w/mods); 89 Maxima GXE
Brian_TII is an unknown quantity at this point
Are you using anything like Red Line's water wetter? It can cause you to see oily stuff in your radiator / coolant bottle.
Brian
87 RX-7 Turbo II
Intake, DP, high-flow cat, HKS Cat-back, F-CON, S-AFC, FD Fuel Pump, HKS EVC-EZ, HKS Super Sequential BOV, FSTB, FCD, ND 720cc Secondaries, HKS Turbo Timer, Hawk HP+ pads. Current dyno output: 212.7rwhp, 211.9lbs - tuned 12:1
95 Integra GS-R (got rice? - I do )
Brian_TII is offline
Old 06-20-2002, 10:11 AM   #3 (permalink)
No im not...
Old 06-20-2002, 01:51 PM   #4 (permalink)
Car: 96 Integra GSR
Mods: ACT HD clutch, CM Aluminum flywheel, AEM CAI, 17" wheels/tires, Zex 55 shot nitrous, Xenon side skirts and rear valence, H&R Race springs, Tokico 5-way adjustables
GhettoGSR is an unknown quantity at this point
sure sounds a lot like a blown head gasket to me. Do a compression test, and if you have two cylinders next to one another that are down on compression, the head gasket is most likely done.
GhettoGSR is offline
Old 06-21-2002, 09:59 PM   #5 (permalink)
EvoLUSA is an unknown quantity at this point
A compression test will do it, but a leakdown test woudl be even better. A Leakdown test will tell you exactly where you cylinder is leaking. You basically remove all the plugs and test each cylinder at TDC. If you hear bubbling or hissing through your dipstick slot, its the rings. The next cylinder, its the headgasket.
Tight like hallways, smoked out always...-southernplayalistic
EvoLUSA is offline
Old 07-07-2002, 08:14 PM   #6 (permalink)
valentinebj is an unknown quantity at this point
My gsr does the samething it was my valve seals that fixed my head and I also in my block my piston rings need to be replaced
95 gsr
AEM cold air intake
DC sports 4-1 header
apex n1 exhaust
valentinebj is offline
Old 07-07-2002, 08:33 PM   #7 (permalink)
Car: 1994 Integra LS
Mods: brown rice.
GunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhileGunNam Needs to go outside once in awhile
Tuan gave me this great URL... hope this helps you with the leakdown test.
http://www.xs11.com/tips/misc/misc3.shtml
GunNam is offline
