There is a special tool you can also use. Tie Rod Seperator/ball joint seperator is what its called and it can use it to take the ball joint apart. Most likely the fork will mess up your boot so you'll have to replace that as well. Might as well anyways since you are reduing the ball joint. Just make sure you lube it up as well.
