belts replacement when donig timing belt change
Do you need to replace the alt, ac, ps belts when changing the timing belt? I am getting the timing belt replace this weekend on 94 Integra gsr, 108k(*previous owner didn't replace it*), so I was wondering should i replace the other 3 belts also.
Do they need to take off the 3 belts before getting to the timing belt? I was thinking if they have too, might as well give them the 3 new belts to replace at the same time. Any help is appreicated. Thanks.
