Old 02-12-2006, 10:04 AM   #1 (permalink)
blakedude is an unknown quantity at this point
Brake Problem
Sometimes when im driving my 95 teg the brake pedal will push in a LOT farther, is this normal? it kinda scares me b/c i dont know if im getting the full power of my brakes, and i wonder what would happen during high speeds. :eek
blakedude is offline
Old 02-12-2006, 10:23 AM   #2 (permalink)
Beangry92GS is an unknown quantity at this point
i'm no expert this is only my 2 cents but i had the same problem in my del sol, sometimes it was normal sometimes to the floor it turned out i needed to replace a rear brake caliper and i could see it was bad when i collapsed it to change the rear disc brakes. hope this might help.
Beangry92GS is offline
Old 02-12-2006, 11:45 AM   #3 (permalink)
thaunforgiven's Avatar
Car: 94 Integra LS
Mods: AEM Style Intake, Custom painted side mouldings, custom painted side skirts, S2K Shark Antenna II, Fat Fives wrapped in Kumhos, Custom Sirius Headunit/Antenna, JDM White Halogens. Header and Exhaust to come :)
thaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond reputethaunforgiven has a reputation beyond repute
you have a bad master cylinder. etiher A) its leaking or B) its very low on fluid. check that out. im pretty sure thats your prob.
Persistency.
Rock on bishes.
Ya. I'm the Indian guy.
thaunforgiven is offline
Old 02-12-2006, 12:39 PM   #4 (permalink)
ATODAB18 is an unknown quantity at this point
bleed your brakes and check your brake fluid
ATODAB18 is offline
Old 02-12-2006, 12:43 PM   #5 (permalink)
Car: 93 prelude si vtec
Mods: jdm h22, header, high flow cat, cat back exhaust, cai, stage 1 exceddy clutch with 8 pound flywheel, gauges in a pod, system...much more to come
johnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhilejohnlude85 Needs to go outside once in awhile
you probably have air in the lines.
93 prelude, jdm h22a, lots of mods great car---FOR SALE
http://www.superhonda.com/forum/showthread.php?t=317981
2005 subaru sti---the beast
johnlude85 is offline
Old 02-12-2006, 01:00 PM   #6 (permalink)
Car: 1994 Honda Prelude SI
G2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problemG2IntegraGS-R has a Rep problem
I have the same problem with my brakes going to the floor sometimes. But I recently changed my MC and its not leaking or low on fluid. I think its either air in the lines or something to do with ABS.
G2IntegraGS-R is offline
Old 02-12-2006, 01:09 PM   #7 (permalink)
ask any tech. a spongy pedal is most of the time directly related to air inthe lines. of course replacing the master cylinder isnt going to fix your problem. if its not leaking or damaged, why replace it?
Old 02-12-2006, 01:20 PM   #8 (permalink)
Mr GSR's Avatar
Car: 1995 Integra GSR BG-33P
Start simple. Check you pads and all that stuff and bleed the brakes. Make sure the pistons in the caliper are working properly. If that doesn't solve the problem, try the master cylinder.
Mr GSR is offline
