I always like to stick with OEM parts, check out the c/r chart:
A0 = USDM spec.
00 = JDM
P73 = Integra Type R
PCT = Civic Type R
P72 = B18c-GS-r
PR3/PW0/P30 = B16a Civic
• PR3 = 89-91 B16A Piston, CR = 10.2
• P30 = 92+ B16A Piston, CR = 10.4
• P61 = B17A Piston, CR=9:7.1
• P72-A0 = US B18C1 Piston, CR=10:0.1
• P72-00 = JDM B18C Piston, CR=10:6
• P73-00 = JDM ITR piston, CR=11:1
• P73-A0 = US ITR piston, CR=10:6
Approximate Compression Ratios
(when using 'R' Pistons in B-series engine(s)):
• Stock B16B CR=10:8
• B16B pistons in B16A CR=11:1ish
• B16B pistons in B17A CR=11.4ish
• B16B pistons in B18C w/GSR head CR=11.8 or more
• B16B pistons in B18C w/ITR or B16A head CR=11.6 or more
• B16B pistons in yo ass CR=15:1...too high !!!
• P73 US pistons in B16A CR=10.4ish
• P73 US pistons in B17A CR=10.6ish
• P73 US pistons in B18C w/GSR head CR=10.8-9ish
• P73 US pistons in B18C w/ITR or B16A head CR=10.6
• P73 JDM pistons in B16A CR=10.6-7ish
• P73 JDM pistons in B17A CR=10.8ish
• P73 JDM pistons in B18C w/GSR head CR=11.3-4ish
• P73 JDM pistons in B18C w/ITR or B16A head CR=11.1
FF Squad Website
It all depends...the higher c/r you go, the more power, but timing is very important...ignition retarding should be adjusted and the use of higher octane fuel is needed to fight detonation. Cam profiles must be takin into consideration....
"A mild cam with an early intake valve closing point will work well at low RPM. But at high RPM the intake valve will close before the maximum amount of air/fuel mixture has been drawn into the cylinder. When this happens performance at high RPM will suffer. If a high static compression ratio is used with a mild cam (i.e. and early intake valve closing point) then the mixture may end up being "over-compressed". This will lead to excessive compression losses, detonation and could even lead to head gasket or piston failure."
The Itr cam has an early intake valve closing point...that is how it gets its great midrange power but lacks the top-end to that of a wildercam. Compared to the characteristics of a more wild cam ex; Skunk2 stage II you'll compromise low end power because of the late valve closing point...but during high rpms more power is being made because more air/fuel is allowed....look at example
"On the other hand, an aggressive cam with a late intake valve closing point will work well at high RPM. But at low RPM the intake valve will close too late for sufficient compression of the intake charge to occur. As a result torque and performance will suffer. If a low static compression ratio is used with an aggressive cam (i.e. a late intake valve closing point) then the mixture may end up being "under-compressed". Thus a high performance cam with long duration should ideally be combined with a higher static compression ratio. That way the engine can benefit at high RPM from the maximized amount of intake charge afforded by the late intake valve closing, and still achieve sufficient compression of the mixture as a by-product of the dynamic compression ratio."
My reply is very sketchy...read the below sites so you can fully understand my reply and how static compression and cam profiles correlate with one another. Good luck
For a more detailed explanation read these websites:
Compression Ratio
How to read uncorrected compression ratio...
ps-I know someone is goin to jump on me because of my reply...sorry
