Car: buy a GS-R, Lude, 300zx, Supra, RX-7 or 3000gt(last 4 will be turbo)
Mods: They will be tight
Cam Shafts
im looking at the skunk 2 camshafts and i see that they have 3 stages. well i was wondering wich stage to get. do u need sertand mods for each stage or are they just ajusted differently, or what :
this stuff is comlicated , its hard bein a noob
Building up you car is like putting together a puzzle. You do it one piece at a time until you have the whole picture.It won't look right if you forgot a piece. Every piece is important, no matter how small the gains
Founder of AfroSheen Racing :thumbsup-Its gunna be big
i'm about to get the skunk2 stage 2 or 3, i haven't yet decide, but you said that it needs higher compression, is it better to use ITR, CTR or JE, i know that if i put JE i'll have to be using a very premium gas like vp or airplane gasoline, so what is recomended?
99 GSR
4-2-1 DC cc
Crower 402's
JE 11.4:1
Custom exhaust 2"
AEM CAI
KYB AGX
H&R Springs
FIELD V-AFC
CLUTCH MASTER STAGE III
MSD SCI
MSD WIRES
VTI intake manifold
NO CATALYTIC CONVERTER
And what valves, shoul i go standerd or high compression (skunk 2), or shouldi g with some type R's or somthin
and what else should i replace cause it says that with the stage 2 u gotta upgrade the valvetrain
thanx for the help guys
u really should consider getting some higher compression pistons to compliment those "bumpsticks". getting skunk2 or jun or toda or any other cams with stock pistons would almost be a waste of money. but this is just a suggestion.
yes, stage 2 skunks are streetable (just like jun 3's). stage 3's are very aggressive for street use.
there is no such thing as "high compression valves". type-r valves would be a nice compliment if ur going to have some head work done -- at least a mild port and polish. and, yes, u will need to upgrade ur valvetrain when purchasing stage 2 or higher.
lastly, (if i were u), i would save up for the piston swap and labor before getting into porting and polishing and valve replacement. as long as the high compression pistons are in, the cams will work much better. head work can be postponed till later when funds are available. (taking the cylinder head off is a lot easier when compared to taking the engine out for the bottom end rebuild.
Originally posted by Tuan Ricer GSR: high compression valves....I think you are going way over your head. sorry to be blunt.
Tuan, feel free to corect me but valves with flat booms will yield higher compression if I'm not mistaking. A rep @ NRG-Racing said that the Skunk2 valves (non-dished) would increase compression by .2 - .3.
I went with these valves along with a Mugen thin HG because I could not afford ITR pistons at the time when my head was at portflow. Although I don't have any compression figures to share, I would bet my compression is around 10.4/1 - 10.5/1. I know it's not ideal for my cams but I'll assume it's better than the stock 10/1 compression of a stock GSR.
Originally posted by IntegraGSR2000 Tuan, feel free to corect me but valves with flat booms will yield higher compression if I'm not mistaking. A rep @ NRG-Racing said that the Skunk2 valves (non-dished) would increase compression by .2 - .3.
Damn your car reminds me of someone elses car. Or the way it used to look.
thats ok im just tryin to figure things out
thanx though
Why do CTR pistons get more compression in my motor than the itR?, the JE will give 12.5:1 like the ctr...how much for ctr pistons $?
99 GSR
4-2-1 DC cc
Crower 402's
JE 11.4:1
Custom exhaust 2"
AEM CAI
KYB AGX
H&R Springs
FIELD V-AFC
MSD SCI
MSD WIRES
VTI intake manifold
in case i got CTR pistons, what mods should i do to my car?.... what time should i break in the engine?.... can i use my rods? and in case i got ITR, i just drop them in?..what break period is recomended?
99 GSR
4-2-1 DC cc
Crower 402's
JE 11.4:1
Custom exhaust 2"
AEM CAI
KYB AGX
H&R Springs
FIELD V-AFC
MSD SCI
MSD WIRES
VTI intake manifold
Dude, try the search function. Absolutely everything you have asked has been asked and answered before. Not ragging it's just that you'll probably find answers quicker if you use the search instead of reasking old questions.
hey how are jun stage 2 cams??? are they equivelent to skunk2 stage 2s??? i have a gsr with bolt ons will i only need to upgrade to stronger valvesprings and retainers, it comes with itr outer valve springs, portflow titanium retainers
and portflow inner springs, will that do the trick?/
