Old 05-25-2006, 08:20 AM   #1 (permalink)
JBauerly is an unknown quantity at this point
Car turning over but will not fire.
Hey all, brand new here and needing some help. I have a 2000 GSR that isn't starting. I'll give you a little background:
When winter came car would occasionally start. It would always turn over but sometimes wouldn't fire. I let it sit throughout winter and bought a beater. After winter I tried to start it and it would never fire at all, just kept turning over. Replaced fuel filter and spark plugs. The car is getting both fuel and spark, we checked those. I took the car to a shop and where it's been sitting for 2 months. They *think* it's the coil/distributor that need to be replaced. The car does have some mods-header, fuel rail, etc. Just curious if there's anything else you think I should have checked or if I should just go ahead and drop the $300 to get those parts replaced?
Thanks for your help!
JBauerly is offline
Old 05-25-2006, 10:09 AM   #2 (permalink)
acuradriva's Avatar
Car: 98 GS-R
if your getting fuel and spark the car should atleast try to start.
acuradriva is offline
Old 05-25-2006, 10:16 AM   #3 (permalink)
SH Virus
95integrars's Avatar
Car: 2005 Mazda 6i (i miss my teg :()
Mods: xxx
95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?95integrars you're still here?
i had the same problem with my integra. i had a shorted ignition coil and had to replace my distributor cap, rotor and plugs.
| 2005 Mazda6 i |
Join the SHO group on Facebook
http://www.facebook.com/group.php?gid=2210247597
95integrars is offline
Old 05-25-2006, 10:25 AM   #4 (permalink)
9400rpms's Avatar
Car: 1997 Acura integra GS-R
Try sticking a screwdriver into the plug socket, and crank it over..either have your friend hold it ( )
Or..put it close to a nut, to where it doesn't touch but it can jump to ground out, to see if you have spark, if you know for sure you got spark / fuel, either
a) your plugs are backwards
b) your sparkplugs are bad
c) you dont have the grounds right
d) make sure ur not getting a cel.
For the love of god, check the firing order of the dizzy and plug wires before you go spend wastless money.
Support ECTUNE - Ectune.com
I Follow No One.
9400rpms is offline
Old 05-25-2006, 10:34 AM   #5 (permalink)
We've done that and for sure are getting great spark.
We've also checked the firing order and all is well, so I'm afraid replacing some stuff may be in order.
JBauerly is offline
Old 05-25-2006, 10:35 AM   #6 (permalink)
It just turns over. Doesn't even try to start and stall. It's weird and frustrating.
JBauerly is offline
Old 05-25-2006, 10:38 AM   #7 (permalink)
9400rpms's Avatar
you 100% sure on the firing order of everything???
if so its gotta be a bad dizzy in gerenal either that or your ecu is bad.
Shit happens.
I Follow No One.
9400rpms is offline
Old 05-25-2006, 11:28 AM   #8 (permalink)
acuradriva's Avatar
Car: 98 GS-R
Is that possible? lol.
Have you tried jumping it? that will rule out the ground wires. Can you hear the fuel pump run when you first turn the key to the on position?
Old 05-25-2006, 11:43 AM   #9 (permalink)
We have tried jumping and no luck. We loosened a nut on my fuel line and turned the key to on position and fuel was flowing like normal.
If it is a bad dizzy or ECU, that's fine. I just want to get it fixed.
I'll drop the money on that and hope that's it.
Are their reasons that cause distributors to go bad? The car is only 6 years old and if there is anything I can do to help it, I'll do it.
JBauerly is offline
Old 05-25-2006, 12:30 PM   #10 (permalink)
9400rpms's Avatar
i ment plug wires..but yes its possible...do me a favor bro i dont mean to insult you or now
but your motor as you stand infront of it, check the wires pos
4-3-2-1
on the dizzy
34
12
I Follow No One.
9400rpms is offline
Old 05-25-2006, 12:43 PM   #11 (permalink)
4-3-2-1
on the dizzy
34
12
No insult at all. I don't know a lot about cars and I know that. My father-in-law is pretty good with them though and he was the one working on it mostly. I will have it checked out. Every little thing will help. I can't wait to get it back.
JBauerly is offline
Old 05-26-2006, 10:41 AM   #12 (permalink)
Syn Inside03 is on a distinguished road
have u checked to see if your getting spark? Do u try the screw driver in the sparg plug wire trick? I had the same problem...it was a bad coil in the distrib. you dont have a msd do u?
Slammin 4 dr
Syn Inside03 is offline
Old 05-26-2006, 02:15 PM   #13 (permalink)
Liquid_Snk's Avatar
Car: S2000
Mods: STOCK!
Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?Liquid_Snk you're still here?
Yous gots gas, you gotz fires, yous gots air. You got a HEMI boy!
Liquid Space
Liquid_Snk is offline
Old 05-30-2006, 09:29 AM   #14 (permalink)
:w00t
JBauerly is offline
Old 05-30-2006, 06:04 PM   #15 (permalink)
Thorgs's Avatar
Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!Thorgs Bow down before me!
Good, someone else ....wait..not good, but someone else with the same problem I'm having. I'm thinking it's my fuel pump...my car had a little bit of a "choppy" acceleration for a while so I'm thinking the fuel pump might have died. I put in my dad's VX distributor into my Si and still no luck starting. My fuel kill switch is off. When I would try starting the car (before it died) it would just try to turn on and that's the problem I'm having now and the switch is off. So other then that...I dont know. I had no CEL come on either. Actually, I just filled up my car and came home. Tried leaving a few hours later and no luck. If you want to see advice from other people go into "Civic" under "I give up..." How do I check for air and fuel? I need to check for spark again because I think I didnt put the plug into the wire all the way because I wasn't getting spark holding it to the block. Sorry this is a long, run-on post. I have been in a slump lately.
PS - Let me know if you figure out your problem, thanks!
Sold 1993 Honda Civic Si
Sold 1995 Acura Integra LS
Thorgs is offline
