I have a 94 Acura Integra RS, non vtec, manual.
The problem I am having is that my car won't start. When I turn the key in the ignition by car won't even crank. I've visually checked my fuses, all appears good. I am able to turn my radio on full blast and my high beams look perfect. I've installed a new starter, but I'm still having the same problem and my car still won't crank. I think it may be a problem with my ignition switch. Does anyone have any ideas or better yet, know how to to check the ignition switch for continuity.
Plus when I installed my starter, I screwed in the two thick bolts, and the two long screws. On the starter solenoid there are two places to attach cables. A cable from the positive battery cable is screwed unto the solenoid by a bolt. The second hole on the starter solenoid is where another cable just plugs right in. Somewhere the female hole on the starter solenoid doesn't look right. I'm thinking I got a an automatic starter. But what is the difference and how can I tell?
Thanks!!!!!
Thanks!!!!!
